problem idle
Old Feb 18, 2005 | 10:46 AM
zerogravitycrx's Avatar
Default problem idle
how do i adjust the idle on my 1989 honda crx hf!
it idle 500rpm and my engine starts to vibrate! is there a way to adjust it?
Old Feb 18, 2005 | 11:54 AM
UltimX's Avatar
Default Re: problem idle (zerogravitycrx)
there should be a brass screw on the tb.
Old Feb 18, 2005 | 10:04 PM
Default Re: problem idle (UltimX)
and then?
Old Feb 18, 2005 | 10:49 PM
UltimX's Avatar
turn the screw and adjust it as nessesary
Old Feb 25, 2005 | 12:14 AM
brass nut!
Old Feb 27, 2005 | 12:44 PM
help please!
Old Feb 27, 2005 | 01:44 PM
crxdonwon's Avatar
there is a screw on the side of the thottle body that hits a piece on your butterfly linkage to hold it open just a little, loosen the nut on the screw and turn the screw to open the butterfly just a little bit more, when you are happy with the idle tighten the nut on the screw
Old Mar 2, 2005 | 01:06 AM
Default Re: problem idle (civicdonwon)
hmm..... i found a flat head screw on the throttle body and adjust it from there, thanks for the help!
Modified by zerogravitycrx at 8:40 PM 3/6/2005
Crxdriver1989
Dec 19, 2017 01:28 AM
oly488
Aug 20, 2014 10:55 AM
followthadollar
Apr 21, 2010 02:46 PM
fe519
Nov 21, 2002 05:58 PM
oi-punx
Nov 14, 2002 02:01 PM
