Search is down. What would cause a blower motor to not work at all?
Old Feb 18, 2005 | 08:59 AM
Jonathan_ED3's Avatar
Default Search is down. What would cause a blower motor to not work at all?
AFAIK, it can't be the blower resistor because that only controls settings 1 & 2. My blower motor does not come on at all in my red car.
I've already checked the fuse and it's good....and nothing seems to be unplugged.
Any suggestions? I thought I've read before that this is a common problem.
I'd really appreciate some help...it's my only day off and the search function isn't working
Old Feb 18, 2005 | 09:02 AM
shauniewalnuts's Avatar
Default Re: Search is down. What would cause a blower motor to not work at all? (Jonathan_ED3)
check the wiring? bad wires? blown motor?
Old Feb 18, 2005 | 09:19 AM
All the wiring is solild.
Is it possible for a motor to just NOT work? Wouldn't it at least struggle, or just be really weak?
Old Feb 18, 2005 | 09:28 AM
skittyscott's Avatar
Default Re: (Jonathan_ED3)
since its an electric motor, it has brushes in it like a starter would... after a while, these brushes and magnets get old and worn out. pull the fan out, unskrew the bottom plate, and there should be 2 magnets and spring behind each one in there. if they're bad, which they prolly are, try to find a new set. the new brushes are like 5 bucks and a fan is about 25 from a JY.
untitled23
Sep 2, 2010 02:56 PM
bodiez
May 13, 2008 07:27 PM
2point2
Dec 31, 2006 09:42 AM
daidilus
Dec 10, 2004 04:16 PM
unclejemima
Jul 19, 2004 04:32 PM
