Aluminum oil pan by Golden Eagle Mfg.
Old Feb 18, 2005 | 08:19 AM
X-Mazda 3 Racer's Avatar
Default Aluminum oil pan by Golden Eagle Mfg.
Well, we have a new product coming out soon. Our aluminum oil pan is one of the nicest oil pans we have seen yet. We are just a little curious as to what some of the other engine builders would like to see as far as baffles and trap doors inside the pan. Your EDUCATED input will be very appreciated. One nice thing about our pan is the fact that the flange is a one piece billet aluminum plate that has been CNC machined, not a flat piece of bar stock like some other pan manufacturers. Here are some pics of the prototype pan:
As you can see in this last pic, the flange is made from a solid piece of aluminum so it will not flex or warp like the bar stock style flanges found on other pans.
We want this pan to be able to be used in a variety of motorsports like drag, road coarse and off-road applications. This pan also houses and extra quart of oil over the stock pan. Let me know your thought on the inside baffling that you like. Thanks
By the way, these pans will be available soon. No prices yet.
Old Feb 18, 2005 | 08:27 AM
Luke J's Avatar
Default Re: Aluminum oil pan by Golden Eagle Mfg. (GoldenEagleMfg.com)
Looks like a quality piece
Old Feb 18, 2005 | 08:28 AM
743power's Avatar
how much lower than stock does it hang?
If you could incorporate a baffle system that works for both RR and drag, you would have a hit on your hands. Have you posted in the RR forum yet?
Old Feb 18, 2005 | 08:29 AM
Default Re: Aluminum oil pan by Golden Eagle Mfg. (743power)
Yes, I posted it in the RR forums. It does not hand lower than the stock pan, we just did small kick-outs on the sides so there would be no ground clearance issues
Old Feb 18, 2005 | 08:31 AM
NOPIDRAGS's Avatar
Hey Vince, will they be available with oil return ports, and for external oil systems?
Old Feb 18, 2005 | 08:33 AM
Default Re: Aluminum oil pan by Golden Eagle Mfg. (NDRATECH)
Yes, they will have the turbo oil return port already in them. It is not in this pic because it was a prototype.
Old Feb 18, 2005 | 08:35 AM
earl's Avatar
http://www.fastlineperformance...e.htm
Check this guy's baffles
You should add at least one turbo oil return plug.
The extra quart capacity is a huge benefit to everyone.
I hope that it is designed to use the stock oil pick-up and dip stick.
You won't be able to make them fast enough.
Great product
Old Feb 18, 2005 | 08:37 AM
Default Re: Aluminum oil pan by Golden Eagle Mfg. (earl)
Earl,
Thanks I will have the oil return port in it and it does use the factory oil pick-up and dipstick That makes it very easy.
Old Feb 18, 2005 | 08:49 AM
f@sth@tch89's Avatar
what would the price be on the oil pan for a b-series(GSR)? what is the weight difference between your unit and the stock one?
Old Feb 18, 2005 | 08:51 AM
regamaster's Avatar
Very nice pan.
I have seen on R/R cars with Kseries the pans need a baffle that will slow the oil from moving ( like a hing door) vs. the stock pan. K-series seem to have this problem when R/R due to the amount of oil moving arround. Seen rods snap due to this problem.
I would run that beautiful piece of work!
When do you plan on releasing it?
Old Feb 18, 2005 | 08:57 AM
V-SPEC 1's Avatar
It would be nice it you can make the top flange look like stock w/ the dimple on them, that make it better for sealing I think. The Moroso drag pan I have w/the flat flange leak and if you torque the nuts down, it'll squees out.
Old Feb 18, 2005 | 09:03 AM
sittin on GOLD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NDRATECH &raquo;</TD></TR><TR><TD CLASS="quote">Hey Vince, will they be available with oil return ports, and for external oil systems?</TD></TR></TABLE>
i was thinking the same thing. another factor would be price too...being a broke *** price is very very important to me
Old Feb 18, 2005 | 01:26 PM
Quitripin's Avatar
looks nice and clean! How soon do you think this would hit the market?
Old Feb 18, 2005 | 01:54 PM
speedworks's Avatar
Default Re: Aluminum oil pan by Golden Eagle Mfg. (Quitripin)
i would be interested in one for an h22 sir.
Old Feb 18, 2005 | 01:55 PM
Danger's Avatar
wow , nice oil pan . would go nice w/ the new motor im building .
ball park idea on the release date ?
Old Feb 18, 2005 | 04:35 PM
NFJohn's Avatar
Default Re: Aluminum oil pan by Golden Eagle Mfg. (JonnnyDanger)
Vince, why not just put a nice ORing groove in it. Get the tool from Destinytool.com and that is it. No leaks, no gaskets. But don't just use and end mill, then the Oring will just fall out.. Get an O Ring cutter.. Go to page 29 on the following PDF http://www.destinytool.com/end...g.pdf Gaskests are outdated, 20th Century technology.. O ring everything..
Old Feb 18, 2005 | 04:38 PM
BoostingSnail's Avatar
Default Re: Aluminum oil pan by Golden Eagle Mfg. (NFJohn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NFJohn &raquo;</TD></TR><TR><TD CLASS="quote">Vince, why not just put a nice ORing groove in it. Get the tool from Destinytool.com and that is it. No leaks, no gaskets. But don't just use and end mill, then the Oring will just fall out.. Get an O Ring cutter.. </TD></TR></TABLE>
That would be a good feature..It's the little things that matter to a customer
Old Feb 18, 2005 | 04:42 PM
Default Re: Aluminum oil pan by Golden Eagle Mfg. (BoostingSnail)
John, we were acutally kicking around the idea of the o-ring! We'll se, it does add some cost to the retail end.
Old Feb 18, 2005 | 05:15 PM
NFJohn's Avatar
Cost in another set up? Or just the ORing cord? Hell, you can throw that my way. I can bang those out for you.. Ha ha.. But, O Rings are the ****..
Old Feb 18, 2005 | 05:39 PM
earl's Avatar
That would be a great idea
Old Feb 18, 2005 | 05:42 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GoldenEagleMfg.com &raquo;</TD></TR><TR><TD CLASS="quote"> it does add some cost to the retail end.</TD></TR></TABLE>
hmmmm, if thats the case...fugg the o ring. i'll sacrifice the o'ring so its better for my wallet
NFJohn's Avatar
Hey, Vince. I don't know how much stuff you do for SRT-4's, but we have made them for that motor.. If you want to make those also, let me know.
Old Feb 18, 2005 | 05:44 PM
Default Re: Aluminum oil pan by Golden Eagle Mfg. (advertise)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by advertise &raquo;</TD></TR><TR><TD CLASS="quote">hmmmm, if thats the case...fugg the o ring. i'll sacrifice the o'ring so its better for my wallet </TD></TR></TABLE>
Your wallet? Don't you have gold plated M7's??? haha
Old Feb 18, 2005 | 05:46 PM
Your wallet? Don't you have gold plated M7's??? haha</TD></TR></TABLE>
my m7s are gold plated, but that doesn't mean my wallet is
Old Feb 18, 2005 | 05:47 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by advertise &raquo;</TD></TR><TR><TD CLASS="quote">my m7s are gold plated, but that doesn't mean my wallet is </TD></TR></TABLE>
hahaha, I gotcha!
