search button broke again?!?!?!?
Old Feb 18, 2005 | 07:46 AM
b16std's Avatar
Default search button broke again?!?!?!?
i need to use the search function and cant now , in a middle of a swap and need some advice on my axle woes...
Old Feb 18, 2005 | 07:59 AM
EP3_05's Avatar
Default Re: search button broke again?!?!?!? (b16std)
What do you need to know?
Old Feb 18, 2005 | 08:18 AM
b16std's Avatar
Default Re: search button broke again?!?!?!? (91civic)
i got my b16 in ..i got the y1 trans with intermidiate shaft.. i got 1 integra axle what other axle works? i heard something about 86-89 axles.. but not sure..
Old Feb 18, 2005 | 08:19 AM
PHOBIA's Avatar
use both intgra axles from a 90-93 integra non abs.you just need to use the int shaft also.
Old Feb 18, 2005 | 08:21 AM
b16std's Avatar
Default Re: (PHOBIA)
even wit the sh3 shaft i beleive it is? it came with the y1 trans?
Old Feb 18, 2005 | 10:28 AM
EP3_05's Avatar
Default Re: (b16std)
No you will need different axles with the Y1 shaft. Check this out:
http://web.archive.org/web/200...s.htm
JustAnotherRex
Jan 9, 2009 05:29 PM
nexgen91
Mar 26, 2006 08:44 AM
crxhf19
Jun 25, 2004 07:52 AM
90hbvtec
Oct 28, 2003 06:10 AM
solman74
Oct 14, 2003 08:59 PM
