Choosing the right wheels
Old Feb 18, 2005 | 07:28 AM
seifer's Avatar
Default Choosing the right wheels
I presently have 16s on my 98 GSR but I've seen a few teggy setups with 17s and fell in love.
Question is, Ive heard Id lose acceleration with 17s because of their higher weight. But what about lightwights? Will a 17 lightweight give the same performance as a non-lightweight 16? or better? or worst?
Also, Is there another factor than the weight to consider in this?
Please shed my light on this.
-Rock
Old Feb 18, 2005 | 07:40 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Choosing the right wheels (fukushuu)
Some will argue that a 17" wheel that weighs the same as a 16" wheel will still be worse because more of the weight is farther out from the center of the wheel. I don't know how much of a difference it makes but it's something to think about.
Other factors to consider is that you're probably going to be running 205/40-17 tires, which have extremely thin sidewalls, which makes for a harsher ride, as well as alot more prone to wheel damage if you hit a nasty bump or hole or whatever, whereas a 205/45-16 tire would be more likely to absorb the impact.
Then there is the issue of aesthetics and ride height. Unless you have zero fender gap already, the shorter sidewall of the 40-series 17" tire will make any fender gap you ahve now appear larger. Most cars look best when the fender gap is equal to, or less than, the size of the tire sidewall. So if, for instance, you had the same fender gap as the size of the sidewall on a 205/45-16 tire, and you switched to a 205/40-17 tire, the fender gap will look bigger in relation to the size of the sidewall. So then you would need to lower the car more to get rid of the "lifted" look.
Old Feb 18, 2005 | 07:43 AM
RuskeR's Avatar
17's on a teg are really only for show.
16's will give you a bigger wheel while keeping the weight down and ride will still be comfortable as a daily.
Old Feb 18, 2005 | 07:56 AM
seifer's Avatar
Default Re: (RuskeR)
RuskeR, Yeah!! but what about lightweights?? Whats you're opinion on these?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RuskeR &raquo;</TD></TR><TR><TD CLASS="quote"> 17's on a teg are really only for show.
Old Feb 18, 2005 | 07:59 AM
seifer's Avatar
Default Re: Choosing the right wheels (PatrickGSR94)
Thanks a lot for the advice, whats the maximum width I can have without having to modify the fenders?
I cant have more than 215 of width right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">Some will argue that a 17" wheel that weighs the same as a 16" wheel will still be worse because more of the weight is farther out from the center of the wheel. I don't know how much of a difference it makes but it's something to think about.
Then there is the issue of aesthetics and ride height. Unless you have zero fender gap already, the shorter sidewall of the 40-series 17" tire will make any fender gap you ahve now appear larger. Most cars look best when the fender gap is equal to, or less than, the size of the tire sidewall. So if, for instance, you had the same fender gap as the size of the sidewall on a 205/45-16 tire, and you switched to a 205/40-17 tire, the fender gap will look bigger in relation to the size of the sidewall. So then you would need to lower the car more to get rid of the "lifted" look.</TD></TR></TABLE>
Old Feb 18, 2005 | 10:06 AM
Community Builder
215 will be pushing it VERY close. I know there are people running 215/45-16 Falken Azenis tires in the ITR forum, mainly because they don't come in a 205/45-16 size. Whether or not you can stuff a 215 tire under there will critically depend upon wheel offset. My 205/45-16 tires are already fairly close to my front spindles on the inside, and the fenders on the outside. So you will have to have a wheel offset that places the tire just right so it won't rub on the inside or outside.
But even with the right offset, it will almost certainly rub on the inside when you're turned at full lock.
Also keep in mind that I'm not running any camber correction, so the fact that I have -2.5 camber in front helps my tires clear the fenders. If you're running an aftermarket camber kit, which pushes the top of the tire outwards, you might have more problems than I do. You might not be able to run a 215 tire at all without fender modification. Unfortunately I can't say anything for sure, though.
Old Feb 18, 2005 | 10:10 AM
seifer's Avatar
What about the diffrence in traction? Is it worth it? Going from 205 to 215... is it a big diffrence?
Old Feb 18, 2005 | 10:16 AM
Community Builder
I don't know, might want to have a look around in the ITR or maybe roadrace/autocross forums, or maybe post in there and see what their experiences and opinions are.
Old Feb 18, 2005 | 10:21 AM
seifer's Avatar
Ok well, thanks for your time and expertise I appreciate it.
DeDonDeRosa
Jul 12, 2007 05:36 AM
huge230
Apr 28, 2007 06:52 PM
dayaftertomorrow33
Feb 5, 2007 04:27 PM
classified
Jan 14, 2006 12:03 AM
non-VTEC
Mar 17, 2002 09:24 PM
