obd0 with vtec?
Old Feb 17, 2005 | 09:38 PM
menappi's Avatar
Default obd0 with vtec?
ok so i have a A6 in my crx now. i came across a y8 long block with bad rod bearings. i broke the timing belt on my a6 so im thinkin i might as well just put the y8 head on the a6 (mini me). but im wondering if there is a way to keep it obd0? maybe use a vafc to control vtec? or should i just convert to obd2?? or obd1? idunno cause the y8 is obd2...can i use a certain ecu to keep it obd0. im not sure what makes a car obd0-2 cept o2 sensors...dizzy too? i dunno what i should do s omeoen provide some guidance!
Old Feb 17, 2005 | 10:01 PM
Redline130's Avatar
Default Re: obd0 with vtec? (menappi)
You can keep it OBD0 by either using a VAFC or a PR3 (B16A) ecu. In either case, just use the A6 dizzy since it bolts up to the Y8 head.
Old Feb 18, 2005 | 10:24 AM
menappi's Avatar
is it a good idea to keep it obd0?? are there sensors on the y8 head n mani that i wouldnt hook up? does everything hook up correcT???? jwjw or should i just convert to obd1-2?
ef_hybrid
34
Jul 2, 2013 09:41 AM
TravisCadello
14
Apr 12, 2009 10:37 AM
toolbox21
Jul 21, 2008 07:29 PM
viskii420
17
Oct 29, 2006 09:01 AM
hondacru27
Feb 12, 2004 02:55 PM
