where can I find a better 02 sensor (ex. bosch)??
Old Jan 18, 2002 | 07:51 AM
hooptie157's Avatar
Default where can I find a better 02 sensor (ex. bosch)??
my 02 sensor is a done deal and I need a new one that can handle higher temps. I know I could just wrap it in foil or zip tie it to the cat but I want a good one to go with my carsound cat. Can you guys help????
Old Jan 18, 2002 | 07:54 AM
sgT's Avatar
sgT
Default Re: where can I find a better 02 sensor (ex. bosch)?? (hooptie157)
they are all pretty much the same
Old Jan 18, 2002 | 08:01 AM
hooptie157's Avatar
Default Re: where can I find a better 02 sensor (sgT)
I had a test pipe on my ITR but I decided to remove it. When I put back on my stock cat I get a check engine light whenever it gets hot. I order a carsound cat from dave and I'm waiting for it to get here (should be sometime next week). Do you think that after I get the cat the check engine light will still come on????
FYI: I have a mugen full exhaust to a twin loop muffler and mugen headers
(if I discount the battery the light goes off until it get hot again)
[Modified by hooptie157, 5:01 PM 1/18/2002]
sgT's Avatar
sgT
Default Re: where can I find a better 02 sensor (hooptie157)
what code is it
Old Jan 18, 2002 | 08:03 AM
hooptie157's Avatar
uhhhh, I not sure but the light does not blink its just on steady, I can turn the car off take the key off turn the car back on and the light is on steady, it never blinks
Old Jan 18, 2002 | 08:20 AM
sgT's Avatar
sgT
you have to short the service connnector to make it blink.
Old Jan 18, 2002 | 08:22 AM
Piston Honda's Avatar
Yes, what sgT said. Stick a paper clip in the service connector to jump it. Then turn on the ignition to count the number of blinks.
Old Jan 18, 2002 | 08:25 AM
b00st-0wnz's Avatar
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
Check the code, here's a howto on it: http://www.bseries.net/html/garage/engcode.php
Old Jan 18, 2002 | 12:43 PM
hooptie157's Avatar
Default Re: where can I find a better 02 sensor (1SlowAssGSR)
until I find out the code (I'm at work right now) do you guys think its a 02 sensor????? if not what else could it be
Old Jan 18, 2002 | 02:32 PM
Its_real&its_spectacular's Avatar
New User
There are a zillion possible codes even on a pre OBD-II car. If it's OBD-II, it might be a silly as having left a gas cap on. It's like asking someone how much money do I have in my pocket... Until it's actually counted, it's kind of a moot point...
preynolds2
Dec 10, 2007 12:30 PM
nuezdaman44
Mar 13, 2006 09:57 PM
2cheapsoidoitmyself
Jan 9, 2006 07:11 PM
ryu12341
Oct 12, 2002 09:16 PM
EliteIntegra
Apr 24, 2002 12:11 PM
