jdm climate control installed
Old Feb 17, 2005 | 08:52 PM
hockey_Fan59's Avatar
Default jdm climate control installed
hey
its all installed and everything. it worked fine until i pluged in the rear defrost button. the fans stopped working. i checked the fuse it was blown so i replaced it. but then the fuse keeps blowing....
what is wrong? the only change in electronic is white light to amber light i believe........
thanks
Old Feb 18, 2005 | 10:41 AM
Default Re: jdm climate control installed (hockey_Fan59)
bump this
Old Feb 18, 2005 | 11:07 AM
Marauder's Avatar
Is it a higher watage bulb? Maybe drawing too much current?
Old Feb 18, 2005 | 11:24 AM
GG-SquadDB's Avatar
Default Re: jdm climate control installed (Marauder)
Wow its ur luck i just had this proble, yesterday...check your wires where ever you connected them and wrapp them with electrical tape ...I found that if you have any tiny peices of wire that touch anything metal when you turn the car on it will just keep blowing the fuse.....check for that hope that helps
Axix24
Honda Fit
Jan 24, 2011 04:24 PM
jerbear!
Aug 13, 2004 02:03 PM
CRX Si
May 26, 2004 07:06 PM
munscher
Mar 7, 2003 11:34 AM
.brad
Sep 10, 2002 07:31 AM
