integra rear disc swap
Old Feb 17, 2005 | 08:32 PM
benjaminenjamin's Avatar
Default integra rear disc swap
the DA trailing arms... etc. get swapped onto EFs all the time without any problems. however i have read on http://home.wideopenwest.com/~tschmidt/ that "92-95 Civic's/Del Sol's and 94-97 Integra's also apparently use the same trailing arm." can anyone else back this statement up?
thanks
-ben
Old Feb 17, 2005 | 08:54 PM
eda6's Avatar
Default Re: integra rear disc swap (benjaminenjamin)
yep.... 92-95 Civic's/Del Sol's and 94-97 Integra's use the same trailing arm.
DA trailing arms are the oddball though. They're identical to the other trailing arms except for a slightly larger trailing arm bushing.
Old Feb 17, 2005 | 09:01 PM
EL Vap133's Avatar
That is correct!
Old Feb 17, 2005 | 09:04 PM
hahagasdcrx's Avatar
Default Re: integra rear disc swap (eda6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 &raquo;</TD></TR><TR><TD CLASS="quote">yep.... 92-95 Civic's/Del Sol's and 94-97 Integra's use the same trailing arm.
DA trailing arms are the oddball though. They're identical to the other trailing arms except for a slightly larger trailing arm bushing.</TD></TR></TABLE>
Actually someone that knows some schit!! LoL
Old Feb 17, 2005 | 09:18 PM
BOSS-REX's Avatar
trailing arms from the 90-93 teg works great. But one day when I was in the junkyard I checked out the trailing arms from later tegs they looked like they would fit but aren't the brakes different on the 94 and ups?
Old Feb 17, 2005 | 09:20 PM
Default Re: integra rear disc swap (hahagasdcrx)
so ur saying they will bolt onto an EF without any alignment issues?
-ben
Old Feb 17, 2005 | 09:28 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by benjaminenjamin &raquo;</TD></TR><TR><TD CLASS="quote">so ur saying they will bolt onto an EF without any alignment issues?
-ben</TD></TR></TABLE>
yep... as long as you don't use the DA compensator arms. Your wheels will have uncorrectable toe-in with DA comp arms. Use ED/EF control arms.
Old Feb 17, 2005 | 09:32 PM
awesome... thanks
-ben
Old Feb 17, 2005 | 09:43 PM
umm now that ive reread this thread ive confused myself. DA trailing arms fit, but will DC trailing arms fit as well? that was my original question, but i dont think i worded it right. sorry for any confusion.
-ben
Old Feb 17, 2005 | 09:49 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by benjaminenjamin &raquo;</TD></TR><TR><TD CLASS="quote">umm now that ive reread this thread ive confused myself. DA trailing arms fit, but will DC trailing arms fit as well? that was my original question, but i dont think i worded it right. sorry for any confusion.
yep...
Old Feb 17, 2005 | 09:53 PM
alright thanks eda6, my bad. i thought you were saying that only DA arms would work.
-ben
Old Feb 17, 2005 | 10:40 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 &raquo;</TD></TR><TR><TD CLASS="quote">yep... as long as you don't use the DA compensator arms. Your wheels will have uncorrectable toe-in with DA comp arms. Use ED/EF control arms.</TD></TR></TABLE>
Yeah you can use DA/DC trailing arms. Use your stock control arms and compensator ( dogbone looking thing up front). If you try to use the DA/DC compensator your toe will be way off, and your trailing arm will rub against the body inside the area for the trailing arm.
Good info eda6
Old Feb 18, 2005 | 04:14 AM
92integra_gs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by benjaminenjamin &raquo;</TD></TR><TR><TD CLASS="quote">the DA trailing arms... etc. get swapped onto EFs all the time without any problems. however i have read on http://home.wideopenwest.com/~tschmidt/ that "92-95 Civic's/Del Sol's and 94-97 Integra's also apparently use the same trailing arm." can anyone else back this statement up?
thanks
Old Feb 18, 2005 | 07:07 AM
EL Vap133's Avatar
Default Re: integra rear disc swap (BOSS-REX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BOSS-REX &raquo;</TD></TR><TR><TD CLASS="quote">trailing arms from the 90-93 teg works great. But one day when I was in the junkyard I checked out the trailing arms from later tegs they looked like they would fit but aren't the brakes different on the 94 and ups?</TD></TR></TABLE>
Nope, the fronts are <u>slightly</u> different though.
Old Feb 18, 2005 | 07:14 AM
mahatma's Avatar
Default Re: integra rear disc swap (EL Vap133)
I'll be raping a '92 DA for it's entire braking system this weekend, all going on the 4dr. So long drums!!
Old Feb 18, 2005 | 08:45 AM
dlric's Avatar
Default Re: integra rear disc swap (mahatma)
you can do this on a '88 crx tho correct? im assuming the ITR style shocks will still work as they bolt onto the lca's...
Old Feb 18, 2005 | 01:42 PM
EJ2-Fluffy's Avatar
Good info. Keep it bumped
Old Feb 18, 2005 | 02:30 PM
CrazyKoreanCrx's Avatar
Default Re: integra rear disc swap (CRX-Fluffy)
What about the brake booster?
Old Feb 19, 2005 | 07:38 AM
90HFCrX's Avatar
for the brake booster you need 90-93 DA brack booster and master cylinder. it will work perfrect. you can use a 94-01 dc booster pack but u have to use the 90-93 DA master cylinder because the lines go to the same side unlike the dc's
Old Feb 21, 2005 | 07:52 AM
dlric's Avatar
Default Re: integra rear disc swap (dlric)
bump to answer my q - you can do this swap on 1988 crx's correct?
Old Feb 21, 2005 | 09:27 AM
CRX_Control's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dlric &raquo;</TD></TR><TR><TD CLASS="quote">bump to answer my q - you can do this swap on 1988 crx's correct? </TD></TR></TABLE> yes , make sure you swap out the lca too.
heres my setup:
Old Feb 21, 2005 | 11:12 AM
Turbo_Mike's Avatar
Default Re: integra rear disc swap (CRX_Control)
jeezus kid, resize that ****
I'm gonan do a DA swap on my car in the next couple months. Where do you order the trailing arm bushings for? I gotta get it for a DA right? becasue the crx bushing would be TOo small? Where's a good place to have these bushings pressed in?
Old Feb 21, 2005 | 06:59 PM
dlric's Avatar
pretty sweet setup.
the thing is, i would like to keep my unique 88 rear suspension. is it possible to do that and still utilize the DC trailing arms?
thanks
Old Feb 21, 2005 | 07:23 PM
yes you can,forgot that the only reason why i swaped the lca also was because i wanted more options for my suspension.
Old Feb 21, 2005 | 07:24 PM
can anyone tell what kind of rear struts i got? i know they kyb, but what type
