18A TO 18B VALVE COVER help
Old Feb 17, 2005 | 07:45 PM
ONESIKUSDM's Avatar
Default 18A TO 18B VALVE COVER help
I need some info on what kind of mods that i have to do to get a b18b valve cover to fit a b18a head. i like the b valve cover better, if someone could point me in the right direction it would be helpful... thanks
Old Feb 20, 2005 | 01:30 PM
ThatRicerDaniel's Avatar
bump cause i wanna know too
Old Feb 20, 2005 | 02:26 PM
hybrid_vtec's Avatar
Default Re: (ThatRicerDaniel)
I want to know whhat to use to plug up the PCV valve hole
Old Feb 20, 2005 | 06:33 PM
Default Re: (hybrid_vtec)
a metal grommit. you dont have to do any modifications. chris stop posting using my name.
Old Feb 20, 2005 | 09:04 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThatRicerDaniel &raquo;</TD></TR><TR><TD CLASS="quote">a metal grommit. you dont have to do any modifications. chris stop posting using my name. </TD></TR></TABLE>
where do you get it from?
Old Feb 20, 2005 | 09:18 PM
BbOi0420's Avatar
Default Re: 18A TO 18B VALVE COVER help (ONESIKUSDM)
bump cuz i wanna know
Old Feb 20, 2005 | 10:04 PM
andrew dc's Avatar
Default Re: 18A TO 18B VALVE COVER help (BbOi0420)
why not just put a pcv valve into the location where its supposed to be and just not run a hose to it. since it doesnt let anything out, wouldn't that work? or if you are uncomfortable, you can run a line off the pcv to no where.
Old Feb 20, 2005 | 11:23 PM
Default Re: 18A TO 18B VALVE COVER help (andrew ef)
yeah you could use the pcv valve but its not very astetically pleasing.
Old Feb 21, 2005 | 06:01 AM
arw321's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid_vtec &raquo;</TD></TR><TR><TD CLASS="quote">I want to know whhat to use to plug up the PCV valve hole</TD></TR></TABLE>
I plugged mine with a bolt and washer and then filled everything smooth with body filler. I did the same with the grooves and also shaved the lettering from the valve cover.
Pic:
Old Feb 21, 2005 | 11:33 AM
b18bEG's Avatar
^^looks pretty damn clean
Old Feb 23, 2005 | 04:11 PM
ONESIKUSDM's Avatar
That is a clean pic of the DA^. Thanx for the info guys.
Old Feb 24, 2005 | 01:11 AM
rovigian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ONESIKUSDM &raquo;</TD></TR><TR><TD CLASS="quote">I need some info on what kind of mods that i have to do to get a b18b valve cover to fit a b18a head. i like the b valve cover better, if someone could point me in the right direction it would be helpful... thanks</TD></TR></TABLE>
I've done it twice, its simple.
I put a screw with tightly wrapped electrical tape into the PCV opening.
Old Feb 24, 2005 | 02:59 AM
BbOi0420's Avatar
Default Re: 18A TO 18B VALVE COVER help (rovigian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rovigian &raquo;</TD></TR><TR><TD CLASS="quote">
I put a screw with tightly wrapped electrical tape into the PCV opening.</TD></TR></TABLE>
Can u please elaborate on this method. Its kinda vague and others may not understand it, thanks.
Old Feb 24, 2005 | 06:11 AM
Hayasa15's Avatar
Default Re: (arw321)
arw321 you filled the valve cover with body filler, has it started to crack from the heat at all?
Old Feb 24, 2005 | 02:14 PM
rovigian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BbOi0420 &raquo;</TD></TR><TR><TD CLASS="quote">Can u please elaborate on this method. Its kinda vague and others may not understand it, thanks. </TD></TR></TABLE>
I kept the PCV valve and plugged it but finding the right size machine screw in my garage. I wrapped the threads in electrical tape to make it air tight, then slowly screwed it in.
Old Feb 24, 2005 | 02:26 PM
arw321's Avatar
Default Re: (Hayasa15)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hayasa15 &raquo;</TD></TR><TR><TD CLASS="quote">arw321 you filled the valve cover with body filler, has it started to crack from the heat at all?</TD></TR></TABLE>
Believe it or not, no. I was concerned it would, but it looks good as new.
Old Feb 26, 2005 | 10:51 PM
ONESIKUSDM's Avatar
^BUMP^
Old Feb 26, 2005 | 11:31 PM
1.6-16 INTEGRA's Avatar
Good info!! I'm planning to do the same mod to my non vtec ls. Always wondered how to do it correctly.
TSX TEX
Dec 1, 2008 05:52 PM
racereaper7
Honda Civic (2006 - 2015)
Apr 12, 2008 06:19 PM
teggy_94LS
Aug 12, 2007 01:12 PM
Slow Ek
Aug 18, 2006 01:09 PM
stackz
Oct 13, 2005 11:05 AM
