Need a Turbo manifold...whats better?
Old Feb 17, 2005 | 06:52 PM
hotimportcrx's Avatar
Default Need a Turbo manifold...whats better?
i have a b16 with a t3 turbo turbo kit ..i dont want to be running no more then 14psi...i got the entire kit except the manifold......what manifold should i buy any suggestions?
Old Feb 17, 2005 | 07:13 PM
beepy's Avatar
Default Re: Need a Turbo manifold...whats better? (HondaDelsol17)
Tell us your budget.
Old Feb 17, 2005 | 07:14 PM
400
Old Feb 17, 2005 | 08:14 PM
beepy's Avatar
Okay, now tell us if you want to use A/C and/or P/S, or if you have other needs. There are a lot of good manifolds out there.
Old Feb 17, 2005 | 09:03 PM
gsrhb7's Avatar
Default Re: Need a Turbo manifold...whats better? (beepy)
Save up $200 more and get a Nuekin manifold
Old Feb 17, 2005 | 09:28 PM
Sivik's Avatar
blox mani, inline pro mani... good stuff...
Old Feb 18, 2005 | 07:48 AM
PrettyLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy &raquo;</TD></TR><TR><TD CLASS="quote">Okay, now tell us if you want to use A/C and/or P/S, or if you have other needs. There are a lot of good manifolds out there.</TD></TR></TABLE>
Old Feb 18, 2005 | 07:52 AM
Rufus523's Avatar
I personally feel that a good cast or log manifold is sufficient for most apps. I saw some HKS cast manifolds for cheap on kteller.com (but I think they are actually t25 flanged).
Old Feb 18, 2005 | 07:58 AM
xenocron's Avatar
Default Re: Need a Turbo manifold...whats better? (Rufus523)
If you can weld or know someone who can do it for you...
http://www.stealthmodeperformance.com/mani.htm
Old Feb 18, 2005 | 08:46 AM
ERL Performance's Avatar
Default Re: Need a Turbo manifold...whats better? (xenocron)
Ours is within your price range!
Old Feb 18, 2005 | 09:36 AM
Boltz's Avatar
Default Re: Need a Turbo manifold...whats better? (ERL Performance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ERL Performance &raquo;</TD></TR><TR><TD CLASS="quote">Ours is within your price range!</TD></TR></TABLE>
***** much?
How about just a link next time
Old Feb 18, 2005 | 07:15 PM
trentepic's Avatar
Default Re: Need a Turbo manifold...whats better? (Boltz)
keep in mind when u say u have everything but a mani, u probably realistically need a down pipe also, so 400 wid down pipe right? becuz if u have a down pipe u want to use its got to match the mani
-Toby
Old Feb 18, 2005 | 08:18 PM
BmCRace.com's Avatar
Default Re: Need a Turbo manifold...whats better? (trentepic)
all of the manifolds we offer are within your price range including the new elf 2.0
Pictured above is Elf 2.0 for a D series engine and is compatible with AC
Milab21
Jul 25, 2008 06:37 AM
b20vtech
Welding / Fabrication
16
Nov 3, 2007 02:52 PM
Jared
Dec 6, 2004 07:06 AM
compact-tuner
Nov 27, 2003 01:55 AM
vtecmissle
Sep 16, 2003 07:32 PM
