Direct bolt on?
Old Feb 17, 2005 | 05:36 PM
baggelis's Avatar
Default Direct bolt on?
Hi
I am planning on buying a 1999 d16y8 from an civic ex. I want to put it into my 91 crx si. I would like to know if the engine and transmission will fit directly on my car. Do I need to do any modifications?
Feedback is greatly appreciated.
Modified by baggelis at 9:53 PM 2/17/2005
Old Feb 17, 2005 | 05:43 PM
T-Mo's Avatar
rywire.com. You will need to add vtec wiring if you want the vtec to work. Search for "d16y8". Make sure you search the archives.
Old Feb 17, 2005 | 05:44 PM
Superhatch's Avatar
Default Re: (T-Mo)
Any D series engine will bolt right into your car. Any D series Transmission will bolt directly up to any D series engine. The wiring, and ECU are the things you'll most likely have to change. (depending on swap).
Old Feb 17, 2005 | 05:52 PM
baggelis's Avatar
Default Re: (Superhatch)
Will that particular engine and transmission set up bolt on directly to the 91 crx si. I want to buy the package and put it on, I dont want to have anything to do with changing transmissions, just want to buy and bolt on.
Old Feb 17, 2005 | 05:54 PM
MINT90EF's Avatar
Default Re: (baggelis)
i thought the transmissions have diff mounts between the hydro trans, and a cable i might b wrong tho
Old Feb 17, 2005 | 05:57 PM
520_Motorsports's Avatar
use the y8 with the crx trans. no mods use original mounts buy a vtec subharness from hasport. you can use your stock ecu with a vtec controller or get a pw0 or pr3 ecu or a zdyne.
hope that helps!
Old Feb 17, 2005 | 05:58 PM
90SICRX's Avatar
couldn't you use the crx tranny?
Old Feb 17, 2005 | 06:00 PM
Superhatch's Avatar
Default Re: (MINT90EF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MINT90EF &raquo;</TD></TR><TR><TD CLASS="quote">i thought the transmissions have diff mounts between the hydro trans, and a cable i might b wrong tho</TD></TR></TABLE>
Sorry...forgot to add that. Any Hydro tranny wont work w/ our cars because we use a cable acuated tranny.
Good catch
The only two direct upgrades you can do, where you still use the same tranny, and not do any rewiring, are the SOHC and DOHC ZC engines.
Here: http://www.hmotorsonline.com/s...30020
ZC 88-91 (Civic) DOHC Long Block
Price: $ 525.00 Plus shipping and handling.
Availability: Sold Out
- Motor
- Intake Manifold
- Exhaust Manifold
- Injectors
- Fuel Rail
- Throttle body
- Alternator
- Distributor
-5 Speed Cable Zc Tranny (add $100)
- Long blocks average 35,000 miles and come with a 100% start up warranty.
And here: http://www.hmotorsonline.com/s...30018
88-91 SOHC ZC longblock
Price: $ 390.00 Plus shipping and handling.
Availability: In stock
- Motor
- Intake Manifold
- Exhaust Manifold
- Injectors
- Fuel Rail
- Throttle body
- Alternator
- Distributor
- 5 Speed Cable ZC Tranny (add $100)Motors average 35,000 miles and come with a 100% start up warranty. All Sensors are guaranteed not broken and in working condition!
SOHC- 120Hp 100Trq 9.1 compression (JDM)
DOHC-129Hp 106Trq 9.6 Compression(JDM)
Old Feb 17, 2005 | 06:07 PM
baggelis's Avatar
Are there any mounts I can get so I can put the hydro tranny on the crx?
Old Feb 17, 2005 | 06:39 PM
you can buy the cable to hydro conversion from hasport. http://hasport.com
RichieRexSi
Transmission & Drivetrain
Dec 31, 2024 10:03 PM
91_honda crx si
Oct 29, 2007 08:48 AM
bassofbob
Dec 29, 2005 10:39 AM
Creep
Nov 25, 2002 09:43 PM
tcc1577
Nov 4, 2001 07:07 PM
