permatex equal to hondabond?
Old Feb 17, 2005 | 04:17 PM
B16Civic93's Avatar
Default permatex equal to hondabond?
is permatex the same thing as hondabond? if so is there a certain type?
Old Feb 17, 2005 | 05:35 PM
eda6's Avatar
Default Re: permatex equal to hondabond? (B16Civic93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16Civic93 &raquo;</TD></TR><TR><TD CLASS="quote">is permatex the same thing as hondabond? if so is there a certain type?</TD></TR></TABLE>
permatex ULTRA BLACK hi-temp rtv silicone gasket maker worked when i swapped tb's. I think it's the same thing.
Old Feb 17, 2005 | 06:34 PM
Padawan's Avatar
Darth ModerVader
Most people consider Permatex Ultra Grey to be the Hondabond equivalent, but I always prefer to use the Ultra Copper (mainly because of it's slightly higher temperature range, but also because it's marketed by Permatex as a "higher-grade" sealant).
Old Feb 17, 2005 | 08:31 PM
SlowReaction's Avatar
Default Re: permatex equal to hondabond? (eda6)
If use both and I think there about the same. Hondabond is a little bit thicker.
Old Feb 17, 2005 | 10:20 PM
PrettyLude's Avatar
Default Re: permatex equal to hondabond? (Padawan)
Permatex Ultra Grey
Old Feb 17, 2005 | 11:00 PM
IN VTEC's Avatar
The Permatex Ultra Grey is still too gooey for me. I stick with Hondabond HT.
Old Feb 17, 2005 | 11:04 PM
deSigi's Avatar
Default Re: permatex equal to hondabond? (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">Permatex Ultra Grey</TD></TR></TABLE>
That's what I've been using. So far so good.
Old Feb 18, 2005 | 07:26 AM
mmuller's Avatar
Mad Scientist
Default Re: permatex equal to hondabond? (deSigi)
hondabond for the important stuff and permatex grey for the not so important stuff
Old Feb 18, 2005 | 08:47 AM
msmotorsports's Avatar
The Permatex ultra copper is all I use. Creates a perfect seal every time. Just apply, let dry until rubbery and put parts back together. Never failed once.
Old Feb 18, 2005 | 04:04 PM
v4lu3s's Avatar
RTFM
the ultra grey is cheaper and works just as well as hondabond, plus it doesnt dry out in the tube nearly as fast.
Old Nov 9, 2023 | 11:12 PM
Ronald_Stevens's Avatar
Originally Posted by B16Civic93
is permatex the same thing as hondabond? if so is there a certain type? Hondabond vs. Permatex
in my experience, Hondabond takes the checkered flag over Permatex when it comes to gasket makers. Hondabond had better seals and stick-to-it-iveness.
Permatex did a middling job on both fronts. When I need to get the job done right, Hondabond is still king of the garage.
1SloSiChick
Honda Civic (2006 - 2015)
Jun 17, 2008 08:55 AM
Scheizty
Nov 29, 2007 08:52 AM
Fabritory
Welding / Fabrication
26
Sep 8, 2006 07:22 AM
@irborne
17
Nov 6, 2005 04:32 PM
wpsadmin
Nov 18, 2004 10:54 AM
