Please help problems with mini me on a mpfi swapped 88 crx auto
I just got my mini me started tonight... it has been in the garage for a month
It is an 88 crx automatic with the dpfi system
I installed a 94 d16z6 head
I bought a new td02u dizzy
I used stock harneddes wehre i could like the dizzy plug and the fuel injector harness... I followed the directions as to what wires to cut and add and so forth... I am 99 percent sure all is correct...
new plugs and oil
I amusing an 88 ecu and have tried another known good 88 ecu ( pm6 )
It cranked for a minute and then roared to life... let it warm up for awhile and was adding coolant to top it off I am going to be using an msd switch to control vtec.. but for now it is not hooked up... i modded the dizzy to fit the block and made spacers for it.. seting it right about in the middle for future adjustment..
THE PROBLEM IS.....
when you rev the car up past lets say 3500 to 4500 ( no tach currently in to see... it just bounces the revs up and down exactly like the stock rev limiter would do at say 7000 spins..
also the computer ( and i tried this with both of them... same result)
while running and with key on engine off will blink out 4 flashes and then 20 flashes... im not sure how to take that... my guess is code 4 and code 20... the 4 flashes seem to be longer than the 20 though.. but code 420 does not seem to make sense ( no jokes here please)
on the computer wiring i have the following wires left over from the conversion
a3 yellow with red stripe
a7 red with black stripe ( I may have confuesd the colors on the top 2 in my description)
b11 green with black stripe that was cut and the pin moved to the b12 spot
b2 orange with black stripe was cut and pin was used for b 10 spot...
I am a little confused by the directions that i used as i was under the assumption that i would need to add a few pins.... but i did not have to ..
once agian my car is an auto and the trans kick down cable is not surrently hooked up....
I would apprecitae any help you could provide...
thanks
Chris
new plugs and oil
THE PROBLEM IS.....
thanks
Chris
goobous
Mar 20, 2011 08:55 AM
toxiclows
Feb 23, 2005 12:40 PM
