crx engine/body harness change in trim?
Old Feb 17, 2005 | 01:15 PM
InMyProject's Avatar
Default crx engine/body harness change in trim?
I am using an hf engine harness with an si body harness..
are they different? will it work.. because it wont start..
Old Feb 17, 2005 | 01:27 PM
fastassdx's Avatar
From: Come back next year and Ill put some, eggnog in your face, US
Default Re: crx engine/body harness change in trim? (InMyProject)
I would think yes, but I do not know for sure. I would test the wires at each end. here is a coulpe for you to test, the four injector wires. test at the injector plug and the correct ecu pin, if the hf/si harness match up then the wires should be good going through the plug. it sounds like you have some wiring troubles. good luck
Old Feb 17, 2005 | 01:37 PM
i dno.. I'm getting fuel.. but no spark.
Old Feb 17, 2005 | 02:05 PM
fastassdx's Avatar
Default Re: (InMyProject)
see if can use somebody's dis. and see if yours is bad? when mine went out it would do everthing but start.
Old Feb 17, 2005 | 02:11 PM
no luck on that one.. i dont know anyone else around here with a honda.... everyone has the drifting fever. got friends with AE86's out the ****.
I just dont see why the dizzy would have problems moving from one car to another..
Old Feb 17, 2005 | 02:29 PM
fastassdx's Avatar
at least check all the wires for it.
Old Feb 17, 2005 | 02:37 PM
Superhatch's Avatar
Default Re: (fastassdx)
I cant say for sure, but I cant imagine that the 1.5, and the 1.6 have the same harnesses. I know that while I was looking for an Si underdash harness I got an HF underdash harness by accident and it didnt work.
Go here (Si harness)
http://www.hondaautomotivepart...RNESS
and here (HF harness)
And you'll notice that only 2 of the 5 harnesses listed in the car are the same part #. They dont have pics though.
Odds are it wont work, unless you make it like an Si engine harness, or use an Si engine harness.
Old Feb 17, 2005 | 02:51 PM
eda6's Avatar
Default Re: (Superhatch)
Pull the 2 wire plug on the dizzy. Make sure you have 12V from blk/yel to earth and 12V from blu to earth. Check the coil and igniter.
Old Feb 17, 2005 | 03:14 PM
Default Re: (eda6)
ya, different part numbers. the engine harness came from an HF.. dropped the engine into an SI.. and left the underdash harnesses. look like im going to have to trade the dashes out too.
Old Feb 17, 2005 | 03:15 PM
and I have checked the wires on the dizzy. I had 12 volts
Old Feb 17, 2005 | 03:49 PM
Rywire's Avatar
Different harnesses, si, dx, hf all different pinouts. Also... fyi years are hardly interchange either(with some exceptions).
Ryan
Old Feb 17, 2005 | 04:12 PM
Default Re: (droppedcrxsi)
ok, so that is definitely a problem? the hf engine harness with the si inside harness? the plugs fit perfectly together.. if i swap out the dash and all that wiring.. everything should be gravy?
Modified by InMyProject at 8:23 PM 2/17/2005
Old Feb 17, 2005 | 07:56 PM
Rywire's Avatar
Yup, or put the hf one back in, lol
Old Feb 18, 2005 | 04:45 AM
lets seee what happens.
Old Feb 18, 2005 | 01:57 PM
anyone else have any suggestions.. an 88 si engine harness in the 90 si.. OR grab the underdash harness from the 90 HF that the engine came out of.. and throw that in the 90 si?
Old Feb 18, 2005 | 02:06 PM
Superhatch's Avatar
Underdash harnesses are a beyotch. You have to pretty much remove everything down to bare metal to get at it. If you can just swap out an engine harness I'd do that first.
Old Feb 18, 2005 | 02:16 PM
the car is already gutted, just took the dash out.. I was told that the 88 si engine harness wouldnt work with a 90 si underdash harness..
Old Feb 19, 2005 | 11:31 AM
just to be sure.
so 90 hf engine harness wont work with a 90 si underdash harness?
Old Feb 19, 2005 | 01:25 PM
fixed.
the guys that made the harness had some wires in different places.
nothing a voltmeter and aligator clips cant fix.
HondaDriver85
Aug 16, 2013 05:13 AM
showcivic96ex
Mar 18, 2011 12:16 PM
duckmanEG
Mar 21, 2007 12:52 PM
90b20b4
12
Nov 6, 2006 12:03 PM
KamikazeRacinz
Mar 10, 2004 02:06 AM
