would a bad fuel pump cause a CEL?
Old Feb 17, 2005 | 11:46 AM
Aphrodavid's Avatar
Default would a bad fuel pump cause a CEL?
my dad's 90 DX hatch(bone stock) has been running like **** for the last 2 days. yesterday it completely died on him. my first thought was the main relay. i replaced it with a known good one and the car still wont start. with the new main relay and his old one, you can hear the initial "hum" of the fuel pump when you turn the key to the "on" position. my question is, if the fuel pump went out, would that cause a check engine light? at the moment, the ecu is NOT throwing ANY codes. because i can still hear the "hum" from the "on" position, does that mean that the fuel pump is still working? also, would a bad ignitor cause a CEL?
Modified by Braveheart at 1:06 PM 2/17/2005
Old Feb 17, 2005 | 11:55 AM
Filthy Focker!'s Avatar
Default Re: would a bad fuel pump cause a CEL? (Braveheart)
About a hundred million things can cause the car to throw a cel. What kind of question is that? Don't go trying to fix a car problem by changing every part you know. Troubleshoot it properly.
If the pump buzzes (for a couple of seconds) when the key is in the start position, then chances are your pump is good.
Now, if your dads car just died, you need to look at a bunch of things.
Is it getting spark?
Does it have fuel in the tank?
What did it do before it died?
fs
Old Feb 17, 2005 | 12:05 PM
Aphrodavid's Avatar
Default Re: would a bad fuel pump cause a CEL? (filthy_shovel)
dude, youre an idiot. you didnt answer a single question i asked. im sorry my post isnt in french, maybe then you would understand it.
01 LudeDude
Sep 29, 2011 06:08 PM
abadkevin
May 14, 2009 09:19 AM
drintegra
Dec 1, 2006 07:56 AM
ssl2k
12
Jun 22, 2005 02:23 PM
XzzYzzX
Jul 31, 2004 08:13 AM
