OiL Light?
Old Feb 17, 2005 | 11:26 AM
linda02916's Avatar
Default OiL Light?
Tuesday nite I noticed one of my lights was flashing, but very briefly.. Last nite I was able to check my oil and it was hella low but to the best of my knowledge I am not burning or leaking any.. any ideas?
Old Feb 17, 2005 | 12:13 PM
AlxSiR7's Avatar
Default Re: OiL Light? (linda02916)
could be your oil pressure.. did it flash while you were stopped or turning hard??
Old Feb 17, 2005 | 12:18 PM
linda02916's Avatar
Default Re: OiL Light? (AlxSiR7)
thats what i think is wrong.. it was barely flickering and almost certainly only while i was turning. it was really frickin low so i dumped some oil in but i want to look at it when it's not raining.
Old Feb 17, 2005 | 12:32 PM
AlxSiR7's Avatar
yeah, it was probably just really low.. our oem oil pans sometimes cause oil pressure to drop while the car shifts directions.. especially if the oil level is low! i'd change your oil and leaks near the drain bolt/filter/and oil pan..also check for any dents in the oil pan and make sure you get a new drain bolt and washer.
Old Feb 17, 2005 | 08:37 PM
Tchleung's Avatar
if you were low on oil. Yes I could see your oil pressure dropping on what I think was left hand turns? I forget which way really effects it. were you turning left?
Old Feb 18, 2005 | 08:24 AM
linda02916's Avatar
Default Re: (Tchleung)
I'm pretty sure I have a problem.. my car is running a little off, I won't be able to change my oil this weekend if this damn rain continues!
I can't member which way i was turning.. but I believe it was both right and left. My clutch is also sticky, but I don't think that's related. Any more ideas anybody>?
Old Feb 18, 2005 | 09:40 AM
VTEC Visions's Avatar
It could be oil pressure. Is your car bogging in VTEC? Get an oil pressure test done asap, but first put more oil in!
Old Feb 18, 2005 | 09:45 AM
linda02916's Avatar
Default Re: OiL Light? (VTEC Visions)
i'm freaked! i'm gonna look at it today on my lunch.. can i get that test done @ like jiffy lube? my shop is HELLA far from work or i'd just run over there.
kingofnothing
Jan 15, 2008 06:18 PM
Billys93prelude
Nov 7, 2007 01:56 PM
98IntegraLSNonVtec
Dec 19, 2005 08:42 AM
951dc5
Feb 15, 2005 06:31 PM
apexrift
Nov 21, 2004 11:23 AM
