90 hatch fuel pump
Old Feb 17, 2005 | 10:44 AM
HondaHookups21087's Avatar
Default 90 hatch fuel pump
ok guys heres my problem. i drive a 90 hatch with a b18b1 and occasionally itll die from time to time but it idles at 500 so i didnt think n e thing of it since it starts right back up. but last night i was leaving my girls apmt and i back up and it died and ever since then the fuel pump wont kick on??????? i dnt want to work on it in an apartment complex parking lot so my main question is can i hook 12 volts to it just to get it home??? and my next question would be do you know where i could check for bad connections?? the car is wired to obd1 but it looks like a sloppy job there are extra wires all over. but n e help would be greatly appreciated. thanks in advance. PS-if i can hook 12 voltz to it which wires would i hook power and ground too?
Old Feb 17, 2005 | 11:04 AM
crxtreme89h's Avatar
Default Re: 90 hatch fuel pump (HondaHookups21087)
You don't have 12 volts hooked up already? If the fuel pump is not kicking on and you have 12 volts, then it is probably your main relay under your drivers side kick panel.
Old Feb 17, 2005 | 12:03 PM
Default Re: 90 hatch fuel pump (crxtreme89h)
bump someone please help!!!!!
Old Feb 17, 2005 | 12:11 PM
CRX Toad's Avatar
Sorry I was no help for you. Hopefully you'll get it taken care of.
Old Feb 17, 2005 | 11:51 PM
Default Re: 90 hatch fuel pump (CRX Toad)
ok so i figured out it was # 14 fuse with the help of CRX toad. i changed fuse and it started a couple times and i drove it home. it died about a block from my house so i changed the fuse and it blew 3 fuses so i pushed it home. now the most itll do is start for a sec and blow the fuse???? then it quit even doing that now it blows them right when i push in clutch????? i need help asap thanks
Old Feb 18, 2005 | 12:44 AM
Mr_CRX's Avatar
Sorry I couldnt help either man.. but here's a bump for some more help. Good luck
Old Feb 18, 2005 | 01:40 AM
Default Re: 90 hatch fuel pump (Mr_CRX)
ttt
Old Feb 18, 2005 | 04:03 AM
92integra_gs's Avatar
your shorting out somehow that is why youre blowing fuses.... its hard to tell... but check the following connection of the following....
1.) Voltage regulator(IG)
2.) Emission control solenoid valves
3.) PGM-FI main relay
4.) PGM-FI ECU (IG1)
5.) FUEL PUMP
6.) EACV
Old Feb 18, 2005 | 11:10 AM
Default Re: (92integra_gs)
bump
Old Feb 18, 2005 | 06:18 PM
Default Re: (HondaHookups21087)
problem solved strut bar rubbed wire loom off my injector harness. thanks for everyones help
90 ef
Aug 21, 2010 05:09 PM
93formula
Jan 11, 2007 03:14 PM
89sicivic
Feb 13, 2006 04:23 PM
BoostNEF
Sep 9, 2005 01:29 PM
antivic
Aug 18, 2005 07:54 PM
