Getting ARP Rod Bolts to Fit LS Rods
Old Feb 16, 2005 | 11:25 PM
SiBuddy00's Avatar
Default Getting ARP Rod Bolts to Fit LS Rods
I have the arp rod bolts, tryin to get the last few mind bugs out before I begin my build. How did you do yours? Can they be hammered in or.... whose got some ideas? Besides take it to a machine shop
Old Feb 17, 2005 | 02:14 AM
hondaguyef's Avatar
Default Re: Getting ARP Rod Bolts to Fit LS Rods (SiBuddy00)
You must take them to a machine shop. Once the rod bolts are pressed in, the big end will need to be resized. It's fairly inexpensive .
Phil
Old Feb 17, 2005 | 02:20 AM
wHOAlly's Avatar
Default Re: Getting ARP Rod Bolts to Fit LS Rods (hondaguyef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef &raquo;</TD></TR><TR><TD CLASS="quote">Once the rod bolts are pressed in, the big end will need to be resized.l</TD></TR></TABLE>
yea, most ppl overlook this when they upgrade to arp rod bolts, u need to resize the big end because of the differnt trq required by the arps.
Old Feb 17, 2005 | 06:53 AM
SiBuddy00's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef &raquo;</TD></TR><TR><TD CLASS="quote">You must take them to a machine shop. Once the rod bolts are pressed in, the big end will need to be resized. It's fairly inexpensive .
Phil</TD></TR></TABLE>
So once they're pressed in, then they get resized? Can I just resize them myself? My buddy has got a machine shop. Is there a lil more detail description on sizes and how this is done? Thanks alot!
Old Feb 23, 2005 | 02:02 AM
SiBuddy00's Avatar
boomp
Old Feb 23, 2005 | 07:21 AM
mmuller's Avatar
Mad Scientist
you have to machine the caps down; torque down the nuts and hone the rod round.
to install the rod bolts you dont need a press though. take the old ones out, put the arp's in(wich wont go all the way in), put the cap in and thighten the nut; that way they seat
Old Feb 23, 2005 | 07:40 AM
hondaguyef's Avatar
Default Re: Getting ARP Rod Bolts to Fit LS Rods (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">
to install the rod bolts you dont need a press though. take the old ones out, put the arp's in(wich wont go all the way in), put the cap in and thighten the nut; that way they seat </TD></TR></TABLE>
Exactly.
By saying "resized", I meant being made round again. The new rod bolts may distort the roundness of the rods ever so slightly so, you machine them to correct that.
Phil
Old Feb 28, 2005 | 01:02 PM
SiBuddy00's Avatar
sorry to be a pain... so... i still don't understand, i do but i don't. Do i tighten them, then take it back apart and take it to a shop to make sure they're sized correctly (the rod cap)? this is the last piece of information i'm missing before i start the build. Thanks!
Old Feb 28, 2005 | 01:06 PM
hondaguyef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">You have to machine the caps down, torque down the nuts and hone the rod round. </TD></TR></TABLE>
Plain and simple
turbod da
Aug 21, 2007 08:41 PM
the DA in HONDA
22
Jan 24, 2006 05:44 AM
turbohf
May 11, 2004 06:30 AM
D
10
Jan 10, 2004 09:03 AM
