Is there a chip burner and chip that works for Uberdata and hondata?
Old Feb 16, 2005 | 09:31 PM
deeweewoo's Avatar
Default Is there a chip burner and chip that works for Uberdata and hondata?
Im looking to go uberdata and my friend is using hondata so we were thinking of getting a chip burner that works for both. Is ther one that most people (tuners) use? also what chip do you most use? Ok one last thing Ive been messing with uberdata and the only thing i cant figure out is how to actually burn your setup. Any help?
Old Feb 16, 2005 | 09:34 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Is there a chip burner and chip that works for Uberdata and hondata? (deeweewoo)
ugh, http://www.ecimulti.org/uberdata
secondly, a chip burner can burn any chip for any application, from an elctronic toaster to uberdata. it all depends on the data fed through the burner and that the chip is the proper for the app.
The most commonly used chip is the Atmel 29c256, but since atmel has quit making it, other people have had to look to different companies.
And you use the software provided with the burner to burn the uberdata - data to a chip
Old Feb 17, 2005 | 10:17 AM
deeweewoo's Avatar
Default Re: Is there a chip burner and chip that works for Uberdata and hondata? (wantboost)
Ok That helps a little I have already downloaded everything from that site and that is what I have been playing with. The Amtel AT29C256 Is what my friend has for hondata and if i get any burner i can reburn his chip and any chip i buy with the same burner. Correct?
Old Feb 17, 2005 | 10:25 AM
rpr's Avatar
rpr
Yup. I have a moates BURN1 (www.moates.net) and it works great. Pretty much the cheapest one I found. He has sockets and chips as well. Great guy to deal with, very helpful
Old Feb 17, 2005 | 10:44 AM
Muckman's Avatar
Moderator in Chief
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote"> a chip burner can burn any chip for any application, from an elctronic toaster to uberdata.</TD></TR></TABLE>
LOL toaster
B I N A R Y 1's and 0's
Its universal.
Old Feb 17, 2005 | 10:50 AM
igo4bmx's Avatar
Default Re: Is there a chip burner and chip that works for Uberdata and hondata? (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">
LOL toaster
Its universal.</TD></TR></TABLE>
1010001110 makes your bread burn so watchout
Old Feb 17, 2005 | 11:01 AM
IN VTEC's Avatar
The chip burner comes with software to write the .bin to the ROM chip.
I use the Intronics Pocket Programmer II. It's the one that Hondata sells. It doesn't do DC power and it's serial port data transfer, so it's more cumbersome to use in the car...if that's how you want to use it.
For tuning while on the move (so I don't have to come home every 2 minutes to make the changes), I use the Intronics Pocket ROMulator....it's also standard Hondata gear.
Old Feb 17, 2005 | 11:02 AM
deeweewoo's Avatar
Default Re: Is there a chip burner and chip that works for Uberdata and hondata? (igo4bmx)
LOL I understand that side of it i just didnt know if hondata and uberdata used the same chip format.
Old Feb 17, 2005 | 11:12 AM
Kowalski's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx &raquo;</TD></TR><TR><TD CLASS="quote">
1010001110 makes your bread burn so watchout</TD></TR></TABLE>
Hahahaha
Old Feb 17, 2005 | 11:34 AM
93turbo16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deeweewoo &raquo;</TD></TR><TR><TD CLASS="quote">LOL I understand that side of it i just didnt know if hondata and uberdata used the same chip format.
How would the ecu read it if they were different formats?
Old Feb 17, 2005 | 11:57 AM
Muckman's Avatar
Moderator in Chief
Default Re: Is there a chip burner and chip that works for Uberdata and hondata? (93turbo16)
Bingo.
Old Feb 17, 2005 | 12:10 PM
Seedc2's Avatar
i was looking to buy a chip burner on moates.net
Id prefer not to spend 85$, so would it be possible to make one? DIY
Old Feb 17, 2005 | 12:15 PM
93turbo16's Avatar
Default Re: Is there a chip burner and chip that works for Uberdata and hondata? (sim shadeee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sim shadeee &raquo;</TD></TR><TR><TD CLASS="quote">i was looking to buy a chip burner on moates.net
Id prefer not to spend 85$, so would it be possible to make one? DIY </TD></TR></TABLE>
the burn1 doesn't burn everything, but I think it is the nicest package out there. Many will disagree, but it is small, you can pul it anywhere, and not have to worry about it really, b/c it is concealed.. and it is fast. But yea, $85 is a lot to spend, but it is a good product, and comes with easy to use software.
Old Feb 17, 2005 | 12:38 PM
96-EJ6 B18C's Avatar
My buddy has the Burn1...I like it way better than my Batronix burner.
Old Feb 17, 2005 | 01:09 PM
deeweewoo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 &raquo;</TD></TR><TR><TD CLASS="quote">
How would the ecu read it if they were different formats? </TD></TR></TABLE>
Ok for example the burn1 doesn't burn everything, It will only burn certian kinds of chips so why would i assume that all chips would work with all applications? But i understand now. Thanks Guys!
Old Feb 17, 2005 | 01:42 PM
93turbo16's Avatar
That has nothing to do with what chips the burner is programmed to support. They all store the same information, but just use different ways of doing it. The most common chip is the AT29C256 chip, and the is reburnable with out the use of a UV eraser, which is very nice.
Anyway, good luck with your burner selection.. if you are only going to use 29c256s then you will be fine with just about everything.
Old Feb 17, 2005 | 06:42 PM
deeweewoo's Avatar
Ok cool thanks alot!
Old Feb 17, 2005 | 07:27 PM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx &raquo;</TD></TR><TR><TD CLASS="quote">1010001110 makes your bread burn so watchout</TD></TR></TABLE>
i dont get it?
654?
28E?
Old Feb 17, 2005 | 09:37 PM
deeweewoo's Avatar
Default Re: Is there a chip burner and chip that works for Uberdata and hondata? (2point2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point2 &raquo;</TD></TR><TR><TD CLASS="quote">
i dont get it?
654?
28E?</TD></TR></TABLE>
WTF?
Old Feb 18, 2005 | 05:43 AM
RudeLude's Avatar
when using uberdata, and tuning do u have to burn to the chip every time u make changes, or can u completly tune the car with the software from ur laptop, and when u get the tune done, then u just burn it to the chip?
Old Feb 18, 2005 | 11:05 AM
IN VTEC's Avatar
Default Re: Is there a chip burner and chip that works for Uberdata and hondata? (RudeLude)
With the ROMulator I use, I always have to shut the car off to write to the ROMulator memory or else it'll cause the ECU to go into limp mode.
If you don't have a ROMulator, then you need to reburn a new chip every time you want the changes to take effect.
Old Feb 18, 2005 | 11:40 AM
DaX's Avatar
DaX
Loved
Community Favorite
i dont get it?
654?
I was thinking 1216 oct....?
1010011010 will send you to hell!
Old Feb 18, 2005 | 12:00 PM
stevel's Avatar
Default Re: Is there a chip burner and chip that works for Uberdata and hondata? (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">With the ROMulator I use, I always have to shut the car off to write to the ROMulator memory or else it'll cause the ECU to go into limp mode.
If you don't have a ROMulator, then you need to reburn a new chip every time you want the changes to take effect.</TD></TR></TABLE>
a faster laptop solves that problem. If it's fast enough you can do it with the car running. My laptop isn't fast enough so I just use the "download current table" and it's small enough data that you can just keep the car running while making changes. It's nice when you're street tuning.
s
Old Feb 18, 2005 | 12:24 PM
RudeLude's Avatar
Default Re: Is there a chip burner and chip that works for Uberdata and hondata? (stevel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stevel &raquo;</TD></TR><TR><TD CLASS="quote">a faster laptop solves that problem. If it's fast enough you can do it with the car running. My laptop isn't fast enough so I just use the "download current table" and it's small enough data that you can just keep the car running while making changes. It's nice when you're street tuning.
s</TD></TR></TABLE>
so with a fast laptop i can make the changes without burning the chip, and when i'm don e i can just burn the program to the chip and i'm finished?
thanks
daniel
Old Feb 18, 2005 | 12:29 PM
DaX's Avatar
DaX
Loved
Community Favorite
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RudeLude &raquo;</TD></TR><TR><TD CLASS="quote">
thanks
daniel</TD></TR></TABLE>
With a fast laptop, a realtime ROM emulator, and a programmable ECU.
