Widest tire 97 GSR
Old Feb 16, 2005 | 09:27 PM
m R g S r's Avatar
Default Widest tire 97 GSR
I have volke TE37's 16x7 don't know the offset. . .
I'm about to order tires, well two at least for the front. I cracked my wheel, and popped my bald toyo proxie, now I'm lookin for tires. I am pretty set on the Falken Azenis Sport. . .
Will a 225 tire fit on the car w/o rubbing? Or should I just go with the orignal planned 215/45/16. . .
Thanks. . .
BTW, sooner you guys answer, the sooner I get the tires and throw the wheels on, which = more pics
Old Feb 16, 2005 | 09:30 PM
m R g S r's Avatar
Default Re: Widest tire 97 GSR (m R g S r)
Actually, the offset is 42, well it says OF +42 4H CR
soooo. . .ya. ..
BTW, I'd say he did a good job fixin it:
Before:
After:
Old Feb 16, 2005 | 09:59 PM
SjCiViCHB's Avatar
Nice wheels.
Old Feb 17, 2005 | 05:36 AM
Chris@Tires.com's Avatar
With that high of an offset, the tire will probably rub on the inside somewhere.
Suprisingly, I still have quite a few of the 215/45 Sports.
Old Feb 17, 2005 | 07:53 AM
m R g S r's Avatar
Default Re: Widest tire 97 GSR (Chris@Tires.com)
So 215 should fit with no problem?
It is dropped on nuspeed Sports with tokico blues. . . .
Can you give me a price on those?
Old Feb 17, 2005 | 09:15 AM
Thrashin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">So 215 should fit with no problem?
It is dropped on nuspeed Sports with tokico blues. </TD></TR></TABLE>
you will be fine with 215s
Old Feb 17, 2005 | 07:19 PM
IntegraBoy04's Avatar
Default Re: Widest tire 97 GSR (Thrashin)
I have the 215s, and I never got any rubbing problems until I changed my camger to -1.5...
Old Feb 18, 2005 | 10:13 AM
UncleD's Avatar
Default Re: Widest tire 97 GSR (IntegraBoy04)
Run 215-40's.....an Integra has the same amount of clearence as a civic, and a 215-45 will throw your speedometer off also. Watch out for rubbing in the back, especially when you have people in the back seat
Old Feb 18, 2005 | 10:38 AM
kineticgsr's Avatar
Default Re: Widest tire 97 GSR (clean rice)
I have seen 225-45-16 on a 95 teg before...but the person wasn't concerned with rubbing...which it did....
215-45-16 is the safe bet
Old Feb 20, 2005 | 03:55 PM
J-J's Avatar
J-J
Default 215/45R16
On a DC2 or DB8 Chassis use 215/45R16, this is OEM for Integra's (ITR in Japan).
Old Feb 20, 2005 | 08:47 PM
shakedown94's Avatar
Default Re: 215/45R16 (js-mode)
712 come in a 225-40-16,listed on tirerack.com
Old Feb 25, 2005 | 06:20 AM
m R g S r's Avatar
Default Re: 215/45R16 (shakedown94)
Well, I got the azenis sports onthe front. . . 215/45/16. . .no rubbing, sticky as hell when its dry, spin like crazy when its wet. . .pics as soon as i clean my cahhh
Old Feb 26, 2005 | 06:59 PM
egizzle8
Guest
Posts: n/a
Default Re: 215/45R16 (m R g S r)
Wow they did an incredible job on that rim. How much did that run you to get repaired?
Old Feb 27, 2005 | 10:02 AM
m R g S r's Avatar
Default Re: 215/45R16 (egizzle6)
Friend of mine. . . Doesn't deal with the public....but $100. ..
Old Feb 28, 2005 | 01:38 PM
98gsrTEG's Avatar
i ran 225 50 15 drag radials on my teg all last summer. i thinks its lowered over 1.5 inches. the only problem i really had was when i hit a really big bump it would rub a bit
Old Mar 1, 2005 | 08:32 AM
VTEC-dood's Avatar
You will clear with no problem no rubbing my buddy (dontblink) 97R with 225/50/15 eibach 1.8 stock shocks in front no rubbing issues at all.
mac_24_seven
Apr 5, 2007 04:46 AM
Integra21
Jul 8, 2005 05:57 PM
SSS2000
Feb 21, 2004 12:07 PM
integral94
Nov 6, 2003 09:46 PM
uncleben
20
Feb 13, 2002 08:02 PM
