weird sputter noise when i accelerate...
Old Feb 16, 2005 | 07:26 PM
boosted ek's Avatar
Default weird sputter noise when i accelerate...
i checked for an exhaust leak but couldn't find any. this only happens when i gas it. if i let go of the gas pedal, the noise is gone. what should i start looking for?
Old Feb 16, 2005 | 07:32 PM
93gsrcoupe's Avatar
Default Re: weird sputter noise when i accelerate... (boosted ek)
Did you check the header? If its stock, you won't see the crack under the heat shield.
Old Feb 16, 2005 | 09:07 PM
boosted ek's Avatar
Default Re: weird sputter noise when i accelerate... (93gsrcoupe)
i checked the header but didn't see anything. i don't have a heat shield on it. i was too lazy to put it back on when i swapped my head.
Old Feb 16, 2005 | 09:11 PM
rob...'s Avatar
what kind of swap did you do?
Old Feb 16, 2005 | 09:13 PM
jerseybrandon's Avatar
Besides the manifold, did you check the rest of the exhaust for leaks?
Old Feb 17, 2005 | 12:07 AM
boosted ek's Avatar
Default Re: weird sputter noise when i accelerate... (baseballinmyass)
LS into EK.
yeah, i checked everywhere. sound is coming from the engine bay for sure though.
Old Feb 17, 2005 | 10:46 AM
boosted ek's Avatar
help...
Old Feb 17, 2005 | 11:34 AM
JoKarma's Avatar
um.. power steering belt on my civic came loose. made a nasty noise that sounded like sputtering.
Old Feb 17, 2005 | 01:31 PM
greenblurr93's Avatar
plugs, wires, cap, rotor fixed the same prob for me.
Old Feb 17, 2005 | 03:36 PM
boosted ek's Avatar
Default Re: (greenblurr93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by greenblurr93 &raquo;</TD></TR><TR><TD CLASS="quote">plugs, wires, cap, rotor fixed the same prob for me.</TD></TR></TABLE>
all these i got replaced recently.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JoKarma &raquo;</TD></TR><TR><TD CLASS="quote">um.. power steering belt on my civic came loose. made a nasty noise that sounded like sputtering.</TD></TR></TABLE>
i don't have power steering but can my alternator belt cause this?
Old Feb 17, 2005 | 04:42 PM
rob...'s Avatar
Default Re: (boosted ek)
does your engine seem down on power? or is it just a noise?
Old Feb 18, 2005 | 07:23 AM
JoKarma's Avatar
Default Re: (baseballinmyass)
I would imagine so. I dont think the sound had as much to do with the power steering as it did the way the pulley was angled.
Old Feb 19, 2005 | 05:26 PM
boosted ek's Avatar
Default Re: (JoKarma)
engine seems to be the same. no power loss. just noise.
i don't have power steering.
Old Feb 19, 2005 | 06:12 PM
rob...'s Avatar
amn it sounds like your screwed. i hate it when you hear noises when your driving that your cant hear when you sit still. it makes it a lot harder to inspect the problem. did you install light weight or underdrive pulleys?
b20acura
Dec 30, 2006 07:44 AM
chue_li
Mar 22, 2005 10:48 AM
supd_up
Acura TL, RL & ZDX
Nov 29, 2004 08:55 AM
civic91
Nov 17, 2004 10:33 AM
96AccordExCpe
Jun 25, 2003 11:33 AM
