Anyone seen this problem before?
Old Feb 16, 2005 | 06:56 PM
excoupe97's Avatar
Default Anyone seen this problem before?
stage 2 clutch on my 94 rs.......when the clutch isnt used for an extended period of time (e.g. riding down the highway, when the car sits over night) it sinks to the floor. well when i'm on the highway it'll drop a little, but wont drop enough to engage, but when it sits over night and i go to get in it in the morning the clutch is sitting on the floor. i have to pick it up and then pump it a couple times and its fine. everytime i shift over 4k rpm it grinds going into gear. i make sure the clutch hits the floor and dont even really jam it, and it still grinds. it doesnt seem like its engaging all the way.
anyone got any ideas?
Old Feb 16, 2005 | 07:24 PM
marsbike's Avatar
From: Salt Lake City, Chicago at heart, UT or IL, USA
Default Re: Anyone seen this problem before? (excoupe97)
It sounds like you've got an air bubble in the line. Try bleeding the clutch. You're pressurizing the system when you pump it, essentially removing the air bubble. Bleed the clutch.
Old Feb 17, 2005 | 08:05 AM
excoupe97's Avatar
Default Re: Anyone seen this problem before? (marsbike)
thanks i'll give that a shot
Old Feb 17, 2005 | 08:06 AM
virusiidx's Avatar
if thats not the problem, then check your master cylinder.
Old Feb 17, 2005 | 08:09 AM
Dan GSR's Avatar
Default Re: (virusiidx)
sounds like clutch master cylinder to me
Old Feb 17, 2005 | 08:10 AM
greaseball's Avatar
Default Re: (Dan GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">sounds like clutch master cylinder to me</TD></TR></TABLE>
Old Feb 17, 2005 | 09:34 AM
spog's Avatar
it is kinda a two person(5 minute) job one of you needs to bleed the clutch slave cylinder and top off clutch fluid while the other is pumpimg the clutch. one person can do it but it will take 3 times as long (almost 15 min)
Old Feb 17, 2005 | 09:53 AM
cnydc2's Avatar
Default Re: Anyone seen this problem before? (slow99gsr)
I also vote master cylinder. Also check to see if any of your hardlines are leaking.
Old Feb 17, 2005 | 10:33 AM
#1151's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marsbike &raquo;</TD></TR><TR><TD CLASS="quote">It sounds like you've got an air bubble in the line. Try bleeding the clutch. You're pressurizing the system when you pump it, essentially removing the air bubble. Bleed the clutch.</TD></TR></TABLE>
Old Feb 19, 2005 | 09:56 AM
excoupe97's Avatar
nope, no leeks.......anyone got a price on a master cylinder, that is what my pops thinks the problem is too. (32 year mechanic) I finally got a chance to take the car to him so he could look at it. (i'm 2 hrs away at college)
Old Feb 19, 2005 | 12:01 PM
cnydc2's Avatar
I think the master cylinder is @$100. Call either Honda or a parts store. Good luck with the repair.
Old Feb 19, 2005 | 03:22 PM
aspec101's Avatar
Actually a more common problem involves the slave cylinder in the transmission. When the seals wear out it will start to leak and give these symtoms. This is definately the cause with performance clutches which cause increased wear on the slave cylinder. Pull back the rubber boot and check for fluid leakage. Also replace asap since clutch/brake fluid will mess up your clutch disc.
Old Feb 19, 2005 | 08:37 PM
spog's Avatar
Default Re: Anyone seen this problem before? (vaperformance)
do you have clutch fluid on your drivers side floor board under your peddals?
Old Feb 20, 2005 | 10:49 AM
excoupe97's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow99gsr &raquo;</TD></TR><TR><TD CLASS="quote">do you have clutch fluid on your drivers side floor board under your peddals?</TD></TR></TABLE>
Nope
needlethread
Feb 12, 2018 07:42 PM
Shyztone1
Jan 22, 2012 03:10 PM
OUTKAST1779
Jul 18, 2009 11:19 PM
bassman
12
Jan 26, 2007 12:01 PM
sniffthese
Sep 30, 2004 11:08 PM
