Swap ? - Do I have to change the clutch cable too?
Old Jan 17, 2002 | 09:23 PM
Count Blah's Avatar
From: A place where stupidity runs rampant aka NorCal
Default Swap ? - Do I have to change the clutch cable too?
S1 tranny attached to a jdm b16 in a 91 civic standard, in my half-awake state i tried to install the clutch cable and it didnt seem to be long enough. I even tried to take off the bracket on the top of the tranny to see if i could get extra slack that way but it still didnt work....so whats up, do i have to use a different clutch cable?
BTW heres a pic of the swap and how far ive gotten....
Thanks
-Todd
Old Jan 17, 2002 | 09:25 PM
89HF's Avatar
New User
Default Re: Swap ? - Do I have to change the clutch cable too? (GymkhanaGTI)
Yeah,use a clutch(and throttle)cable for a 90-91 Integra.
Old Jan 17, 2002 | 09:29 PM
rioninja's Avatar
If you wanna be cheap, you can modify the stock cable. Take a dremel and take an inch or two out of the cable sleeve at the end. And hey, if you screw it up you can just buy the 90/1 ls one like most people
Old Jan 17, 2002 | 09:37 PM
Count Blah's Avatar
Default Re: Swap ? - Do I have to change the clutch cable too? (RioNinja)
Thats a damn good idea...im gonna try that!!
-Todd
Old Jan 17, 2002 | 09:38 PM
rioninja's Avatar
Oh, and DAMN! i just noticed you had no intake mani, or wiring harness installed. Hopefully you didnt put the intermediate shaft on yet, it will make it a little easier to install the manifold without it. The wiring harness is gonna be a major pain in the *** also. I always install the entire engine harness before i drop the motor in. The stock si harness is a tight fit in some spots, but it'll fit. good luck man
Old Jan 18, 2002 | 12:28 AM
kefka's Avatar
poor valve cover (mean shiping people.)
ryanevansoh
Mar 23, 2009 02:02 PM
slayerP
Apr 5, 2008 01:34 PM
Msnier85
Aug 3, 2007 02:59 PM
user 72830283
40
Sep 22, 2005 12:06 PM
90civichbsi
12
Sep 9, 2002 06:41 PM
