ok. will rear negative camber hurt tires? is it good or bad if fell upon?
i want to get 92-95 lca's for my '90 hatch (they are aftermarket lca's)
and someone on here said they add negative camber, becuase they are 1/16 inch longer. it doesnt seem to me that would add too much camber,
so would mess up tire wear if i had these lower control arms on my car?
also, are the aftermarket lcas fo 92-95's different then stock? like on ebay they say that they are to accomidate widder rims.
i am having trouble finding stock lca's for my car, and for the price i can get the aftermarket ones for like 30-40 more, WITH bushings. junkyard will probably have to replace bushings anyways.
(i am stuck with teg arms on my hatch right now)
thanks.
thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _OEM_ »</TD></TR><TR><TD CLASS="quote">negative camber won't hurt at all unless your like -3. just make sure when you get your alignment they set the toe to 0 and rotate your tires often. </TD></TR></TABLE>
oh yeah i am talking about rear lower control arms
my bad...
my bad...
hatchetmansmybro
Sep 21, 2006 04:15 AM
