how many quarts of mtf?
Old Jan 17, 2002 | 08:45 PM
Gump's Avatar
Default how many quarts of mtf?
i just changed my tranny fluid a couple of weeks ago, and resently i've been having trouble getting into reverse, someone told me that its because i did not put enough mtf (i put 2.5 quarts) so how much are you supposed to put?
[Modified by xlr8 si, 5:45 AM 1/18/2002]
Old Jan 17, 2002 | 08:57 PM
sgT's Avatar
sgT
Default Re: how many quarts of mtf? (xlr8 si)
2.5 is more than enough
takes just over 2, like 2.2
Old Jan 17, 2002 | 09:21 PM
B2FiNiTY's Avatar
Just a bit over 2.
Old Jan 17, 2002 | 09:34 PM
Gump's Avatar
Default Re: how many quarts of mtf? (sgT)
ok, if its only about 2.5 then why do i suddenly have a problem of getting into reverse? i have to go into first and second then reverse just so it will go in with ease. also one more question how many people put the new mtf through the hole where the vehicle speed sensor (v.s.s.) goes? thats where i put it and its a whole lot easier than through the bottom.
Old Jan 18, 2002 | 08:44 AM
R R's Avatar
R R
ur suppose to go into first gear then reverse to syn. the gears if u want to do a reverse..
r
Old Jan 18, 2002 | 11:18 AM
Gump's Avatar
Default Re: how many quarts of mtf? (RICKS R)
r
i never had to go into first before, till now.
Old Jan 18, 2002 | 11:51 AM
albert butterbikini's Avatar
New User
i recently changed my mtf and i put in at least 2.5 quarts(thats how much it took before it started running out the top hole. i have been having some trouble lately getting into first too, i am wondering if i put in too much mtf. where is the speed sensor located?
Old Jan 18, 2002 | 01:24 PM
forksports's Avatar
I think its a common problem for most honda trannys, I usually just put it in 1st then R....or release the clutch & press it again, try put into R again.
Old Jan 18, 2002 | 01:27 PM
HX_Guy's Avatar
Default Re: how many quarts of mtf? (forksports)
You might have put too much, I think the actual spec is 2.2 quarts
I always just put 2 quarts
Old Jan 18, 2002 | 02:25 PM
nsxtcjr's Avatar
New User
Because you forgot to open the garage door before trying to back out.
Old Jan 18, 2002 | 07:40 PM
Gump's Avatar
Default Re: how many quarts of mtf? (typeR158)
on the top of the tranny near the charcoal canister can't miss it, it only has one nut holding it down
JENNY_EG6
12
Sep 25, 2009 08:43 AM
HatchSpeeD
Transmission & Drivetrain
11
Mar 23, 2009 12:13 PM
BB1 pOwA!!
Aug 24, 2007 11:03 PM
B16Jacques
Sep 15, 2006 04:06 PM
SpleenBoy
Feb 12, 2006 07:14 PM
