Which sway bar 22mm or 23mm?
Old Feb 16, 2005 | 11:39 AM
Khmai_guy's Avatar
Default Which sway bar 22mm or 23mm?
Looking to get a itr rear sway bar for my 96 dc2. I'm looking at passwordjdm's itr 22mm and 23mm. Which one is recommend and which is more stiff? The 23mm is 20 dollars and is it worth it? thanks.
Old Feb 16, 2005 | 11:43 AM
The-LS's Avatar
Default Re: Which sway bar 22mm or 23mm? (Khmer_DC2)
I believe the 23mm is the JDM ITR, and its obvious that would be stiffer. I believe you'd need different bushings?
Old Feb 16, 2005 | 11:50 AM
Your Epitaph.'s Avatar
///M Power
Default Re: Which sway bar 22mm or 23mm? (Black-LS)
Remember, thicker and stiffer is not always better.
If you have an unbalanced rear end, oversteer is going to become your best friend.
If you have a fairly built-up front end to accompany the 23mm, than go for it. If not, stick with the 22.
Old Feb 16, 2005 | 02:48 PM
Khmai_guy's Avatar
Default Re: Which sway bar 22mm or 23mm? (Your Epitaph.)
Ok thanx, i'll guess I'll go with 22mm. !
Old Feb 16, 2005 | 04:10 PM
btatedash's Avatar
just so you know, that sway bar is only 60 bucks from acuraparts247.com
Old Feb 16, 2005 | 04:19 PM
Khmai_guy's Avatar
Default Re: Which sway bar 22mm or 23mm? (btatedash)
searched that site for type r parts and so far nothing.
Old Feb 16, 2005 | 04:32 PM
btatedash's Avatar
??? on the front page, on the right side there is a search method that says "search by vehicle" or something with a radio button for either parts or accessories. pick parts and integra, then the year, then the type-r trim level, then on the next screen click "view all" or something along those lines.
search here on h-t for the member BSQ, and in his profile he's got a link to his page that has the whole how-to on the itr swaybar, including part #s to order
Old Feb 16, 2005 | 04:52 PM
njandrewg's Avatar
it ends up being 120 in the end...60 bucks for sway bar...then 50-60 bucks for all the bushings/bolts, and then 20+ for BSQ/beaks kit
Old Feb 16, 2005 | 05:48 PM
Ls InTeGrA RaCeR's Avatar
Default Re: Which sway bar 22mm or 23mm? (njandrewg)
how much does this help?
Old Feb 16, 2005 | 06:21 PM
jadebellyt's Avatar
22mm is what I have and chose over the 23mm. I figured if the rest of my suspension wasn't up to par and couldn't handle the extra stiffness in the rear, why get it and have the possibility of tear out. I have blown stock shocks, sportlines, and a stock front setup and I was just worried about the 23mm being a little too stiff. Also, the japanese integra type r's have a 1mm thicker front sway as well to go along with the 23mm rear. So I think 24mm front and 22mm rear pair up nicely on a stock/near stock suspension setup to get closer to neutral characteristics.
Old Feb 16, 2005 | 06:34 PM
Racermech's Avatar
Default Re: (jadebellyt)
i got mine from acuraparts247 for 90 shipped with bushings and all. I put it on last week with the BSQ kit and it fit great. Now i just have to get the car running to give a driving review
Old Feb 17, 2005 | 06:21 AM
VTEC Visions's Avatar
Either one will be fine
Old Feb 17, 2005 | 06:41 AM
timmy8151's Avatar
Default Re: Which sway bar 22mm or 23mm? (Ls InTeGrA RaCeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ls InTeGrA RaCeR &raquo;</TD></TR><TR><TD CLASS="quote">how much does this help?</TD></TR></TABLE>
The 23mm is going to be 19.5% stiffer than the 22mm bar. IMHO, most drivers really won't be able to tell the difference between the to bars.
If you're talking about an ITR bar over an OEM bar, then the 22mm bar is going to be about 6X stiffer than say a stock 14mm bar.
Old Feb 17, 2005 | 07:22 AM
njandrewg's Avatar
Default Re: Which sway bar 22mm or 23mm? (timmy8151)
isn't the stock bar 12mm?
Old Feb 17, 2005 | 07:28 AM
jadebellyt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by njandrewg &raquo;</TD></TR><TR><TD CLASS="quote">isn't the stock bar 12mm?</TD></TR></TABLE>
It's 14mm in the rear for 94+ integras excluding type r.
Old Feb 17, 2005 | 03:52 PM
Default Re: Which sway bar 22mm or 23mm? (jadebellyt)
And the Type R just bolts right up to an Ls? If so good deal. I'll have to order one in a week or two.
Old Feb 17, 2005 | 04:05 PM
timmy8151's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ls InTeGrA RaCeR &raquo;</TD></TR><TR><TD CLASS="quote">And the Type R just bolts right up to an Ls? If so good deal. I'll have to order one in a week or two.</TD></TR></TABLE>
There more than just bolting it on. You'll need to purchase some bushings and brackets as well as a subframe kit. I highly recommend you go to BSQ's site: http://geocities.com/bretq/swaybar_install.html
Old Feb 17, 2005 | 04:30 PM
Just out of curiousity....is there another bar that serves the same purpose (intensity) that bolts right up?
Old Feb 18, 2005 | 05:22 PM
nzrnk's Avatar
Yahh the Comptech Swaybar/ tie bar combo, but it's loot!! $350 cheapest
royalrebel
Suspension & Brakes
Dec 19, 2008 04:49 PM
Grandmasta
Feb 29, 2004 03:21 PM
TurboBumblBee
Nov 6, 2003 07:05 AM
DeSolMan007
Apr 7, 2003 08:22 PM
RS_POWER
Jun 5, 2002 06:09 AM
