CTR N1 CRANK PULLEY VS SHAVED STOCK b series PULLEY
Old Feb 16, 2005 | 11:00 AM
HONDA RR's Avatar
Default CTR N1 CRANK PULLEY VS SHAVED STOCK b series PULLEY
The machine shop told me that it was better to shave the ac and ps pulley of my stock gsr pulley instead of buying the ctr n1 crank pulley. He told me if i was going to use my car for street use to not install the ctr pulley because it doesn't have a damper which could do some engine damage. Is it true what he's saying? He also told me the pulleys that do not have a damper like the ctr n1 are only used for race conditions .
Old Feb 16, 2005 | 11:56 AM
h22 civic's Avatar
Default Re: CTR N1 CRANK PULLEY VS SHAVED STOCK b series PULLEY (MITSUBA)
i shaved and balanced mine with no probs works good
Old Feb 16, 2005 | 01:16 PM
NJIN BUILDR's Avatar
Your machine shop is right.Use the stock one with the pulley shaved off.
Glenn
Old Feb 17, 2005 | 06:04 AM
HONDA RR's Avatar
Default Re: CTR N1 CRANK PULLEY VS SHAVED STOCK b series PULLEY (NJIN BUILDR)
I would i know if the machine shop balanced my cranfshaft pulley?
Old Feb 17, 2005 | 07:10 AM
I don't know ,maybe because they said they did.If you don't trust your machine shop, try another one.
Glenn
Old Feb 17, 2005 | 08:46 AM
Combustion Contraption's Avatar
CTR pulley here for 6900 miles and no problems whatsoever. You guys ever stop and think that when you attach the alternator belt it would dampen most of the vibrations?
Old Jun 22, 2006 | 08:31 PM
maluseanjohn516's Avatar
Default Re: (Combustion Contraption)
when u install a ctr crank pulley do u have to change ur alternator pulley ??? becasue the grooves are different
Old Jun 23, 2006 | 10:41 AM
93Civic_hb's Avatar
Default Re: (maluseanjohn516)
That wouldn't be necessary to change your alternator pulley. Althought you do have to go and get a different size belt. I was direct to getting a certain one from NAPA and that is what I have been using for at least two years now. My setup is a GS-R in a EG chassie. If you need the NAPA part number I can dig it up for you?
Old Jun 23, 2006 | 11:19 AM
Default Re: (93Civic_hb)
o **** really thanks man can i get that #
Old Jun 23, 2006 | 05:53 PM
b18sihatch's Avatar
Default Re: CTR N1 CRANK PULLEY VS SHAVED STOCK b series PULLEY (HONDA RR)
i have done alot of reading about the n1 pulley. if you think about it the 88-91 b16 pullies didnt come dampered from the factory making it just the same as the n1.. there isnt anythnig to worry about
Old Jun 24, 2006 | 04:12 PM
93Civic_hb's Avatar
Hey man got the Napa Number for you. It is #040292
sl_e_pr
Jan 13, 2007 01:38 AM
IGotNoSwap
21
Sep 27, 2005 08:17 PM
Civic Minded
Apr 28, 2004 03:43 PM
SiZ
23
Jul 24, 2003 01:16 AM
SiRex91
Nov 24, 2002 03:22 PM
