integra dash in civic problems
Old Feb 16, 2005 | 10:28 AM
neEven's Avatar
Default integra dash in civic problems
just wonderin if anyone has run into problems makin the ac "lines" i guess fit or match up...it looks line im gonna have to cut out some plastic and make an adapter from the civic to the teg...i donno just lookin for suggestions or anythin
96teg dash into 92 hatch. no wiring questions just tubes matchin up and mounting question
thanks
i know that probably doesnt make alot of sence but im retarted and couldnt find what i was lookin for when i searched
Old Feb 16, 2005 | 10:29 AM
litterbox's Avatar
I am a (Trial User) Army
Default Re: integra dash in civic problems (neEven)
Well for the teg dash swap you need to use the teg heater core and fan blower. Or at least the one that is in the middle of the dash (forgot the name).
Old Feb 16, 2005 | 11:40 AM
georgj's Avatar
Default Re: integra dash in civic problems (litterbox)
You can actually unscrew the top vents off of the intetra heater box and screw them onto the civic box. The boxes are identical, aside from the top vent ports that you can unscrew.
Old Feb 16, 2005 | 09:23 PM
neEven's Avatar
i dont have the anythin from a teg to work with but the dash so i cut the top of the three ports at an angle into 1 big hole and im gonna rig up some duct tape and posterboard a little adaptor and it will work out fine cause thats the stupid **** i do...thanks for the replys
if i had the right parts id like to do it right...maybe later if this doesnt work out
thanks again
Old Feb 24, 2005 | 10:33 AM
neEven's Avatar
Default Re: (neEven)
does anybody know where to find the center vent i need for the teg heater box???
even better does anyone have one??
thanks
ecksman
Apr 2, 2004 07:42 PM
B18Cej1
Feb 11, 2004 03:31 PM
