how to pass smog
here is the thing i went to the state ref for modified emissions, so i fixed everything and put the car back to stockbut the test still showed i had a high O2 level and a low Co2, sowmthign about the hydro carbons and the Nox, so if any one has any answers p[lease help, oh its a 1994 civic ex
Modified by 94oemcivic at 2:33 PM 2/16/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94oemcivic »</TD></TR><TR><TD CLASS="quote">here is the thing i went to the state ref for modified emissions, so i fixed everything and put the car back to stockbut the test still showed i had a high O2 level and a low Co2, sowmthign about the hydro carbons and the Nox, so if any one has any answers p[lease help, oh its a 1994 civic ex
Modified by 94oemcivic at 2:33 PM 2/16/2005</TD></TR></TABLE>
How about your o2 sensor, and spark condition, not to mention your cat?
your car is running lean. check fuel pump, filters and injectors. if your nitrides of o2 (nox)are high then you might have a timing problem but it is also caused by lean conditions. your cat is working fine especially if your hydrocarbon emissions were low, also a sign of leaning out. co2 is the result of fuel and o2 mixing if your running lean then your co2 will be low.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Transformer »</TD></TR><TR><TD CLASS="quote">Also, you should try to find a smog tester who knows how to drive it right. Your rim size and having low profile tires factors in.
only if you're on a dyno, and even if you are, the engine speed will barely vary due to tire size.
</TD></TR></TABLE>only if you're on a dyno, and even if you are, the engine speed will barely vary due to tire size.
the thing is my dad is a master mechanic, we fine tuned that bitch down to the bone its running stock time idle throttle everything its like perfect and its not a racing cat its brand new stock, so im not real sure i guess ill check the fuel pump injectors and filters, thanks for the input
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baseballinmyass »</TD></TR><TR><TD CLASS="quote">wtf does tire size have to do with the smog test?</TD></TR></TABLE>
lols
lols
can you by chance post your results? exact numbers of each at idle and 2500 or whatever they test it at? also before you go again change the oil and drive it before you go and DONT turn the car off while you're waiting in line. the warmer the cat the better
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civicr2gs5 »</TD></TR><TR><TD CLASS="quote">has anyone passed with a motor with out a cat.......like sohc vtec, b-series non/vtec??</TD></TR></TABLE>
highly doubt it.
To the original poster, do a basic tune up and make sure the car is warmed up and up to operating temperature.
highly doubt it.
%CO2 %O2 HC (PPM) CO2(%) NO (PPM)
TEST RPM MEAS MEAS MAX GP MEAS MAX GP MEAS MAX GP MEAS
15m 1869 11.7 4.3 92 281 167 0.55 2.05 0.10 716 1961 4211
25m 2026 12.3 3.5 57 321 75 0.54 2.04 0.01 764 1761 3780
rodvang
20
Oct 2, 2007 10:58 AM
