GSR Burning Oil
Old Feb 16, 2005 | 06:00 AM
seifer's Avatar
Default GSR Burning Oil
Hey techs,
My 98 GSR burns a lot of oil... I have to put a small bottle (1 litre) about once a week (if Im often in the VTEC that week).
Some people told me its most likely the PCV valves, some others told me it would be the piston rings...
My car is all stock and has reached 135,000 KMs (~84,000 miles).
I just wanna know what is the most known issue for GSR engines burning oil; piston rings, pcv valves, both? something else?
Thanks!
Old Feb 16, 2005 | 06:04 AM
lanojp1's Avatar
Default Re: GSR Burning Oil (fukushuu)
do you have a loss of power? alot of bogging? backfiring?
i just blew a set of rings among other things in december...shes getting rebuilt right now..
Old Feb 16, 2005 | 06:22 AM
seifer's Avatar
Default Re: GSR Burning Oil (lanojp1)
no loss of pwoer at all.. no backfiring not much bogging, everything feels normal and powerful when driving ... but still burning oil...
Ive heard that if piston rings are worning out it could make a leak for oil to be burned along.. is it true?
Old Feb 16, 2005 | 06:31 AM
lanojp1's Avatar
it doesnt sound like piston rings...my car would idle, but would barely drive...you would have a loss of power because of a drop in compression...idk what ur problem could be...
does it smoke at all? any leaks undercar?
Old Feb 16, 2005 | 06:38 AM
luckypon7's Avatar
do a compression test to see if the rings went bad. you look all around to see if there is cam seal or cam plug leak? maybe distrubitor o ring, valve cover gasket?
Old Feb 16, 2005 | 06:39 AM
simon98h22's Avatar
Have you checked the PCV valve?
seifer's Avatar
no leak... im not losing oil that way.. only burning it.. not much smoke neither...
but what about PCV valves? I heard that a dirty pcv valve can cause excess pressure on internal oil seals and gaskets...
Old Feb 16, 2005 | 06:40 AM
seifer's Avatar
Default Re: GSR Burning Oil (simon98h22)
simon98h22, thats exactly what I was wondering, but Im not sure how I can test these?
Old Feb 16, 2005 | 06:41 AM
lanojp1's Avatar
compression test/ leakdown test....that might give you an idea....
Old Feb 16, 2005 | 06:42 AM
luckypon7's Avatar
Default Re: (lanojp1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lanojp1 &raquo;</TD></TR><TR><TD CLASS="quote">compression test/ leakdown test....that might give you an idea....</TD></TR></TABLE>
do these test
Old Feb 16, 2005 | 06:44 AM
lanojp1's Avatar
its only a 100 bucks for these tests at the dealer...or you can do them yourself...
Old Feb 16, 2005 | 06:48 AM
cnydc2's Avatar
Is your oil pan leaking? Honda pans are noted for warping and not seating right.
Also check your spark plug tube seals, could be leaking and going down the spark plug.
Is there any blue smoke out of your exhaust?
Old Feb 16, 2005 | 06:49 AM
lanojp1's Avatar
Default Re: (cnydc2)
he said he wasnt leaking oil only burning it...
Old Feb 16, 2005 | 06:53 AM
seifer's Avatar
cnydc2, no blue smoke, no leaking... and I changed my spark plugs and wires and I checked the tube seals and its ok...
I presently opt for deffective or worned PCV Valve.. since I dont THINK I am losing compression or anything... I feel full power.. and Im pretty sure I would notice a loss of compression/power.
Ill checkt he PCV Valve... if no go Ill do a compression test, thanks a lot everyone!!
But at last, where's the pcv valve located?
Old Feb 16, 2005 | 07:02 AM
simon98h22's Avatar
Default Re: (fukushuu)
On a GSR ? I think it's located at the back of the valve cover and down towards the block. Look for a diagram/picture on here or look it up in your service manual.
Simply unplug it (gently ply/pull it out) and rattle it, if you can hear clicking/rattling ? It's still working. If you hear nothing ? It's clogged and needs to be replaced. Good news is that it's a 2-5$ part. I change mine every 25K kms.
If it's shot, you will burn oil.
Old Feb 16, 2005 | 07:22 AM
seifer's Avatar
Default Re: (simon98h22)
BTW, just for the hell of it, thats a cat that was stuck in my engine, I wrestled for 1 hour and a half to get it out
Grrrrr :@
Old Feb 16, 2005 | 07:25 AM
Tyler1121's Avatar
LOL poor cat
Old Feb 16, 2005 | 07:35 AM
seifer's Avatar
Default Re: (Tyler1121)
haha , he was a bigggg one :D
I should get it stuffed and put it as an emblem on the hood!! haha
FireInTheHead
Nov 4, 2014 04:15 PM
jdawg916
Apr 10, 2011 03:37 AM
joss731
Sep 15, 2010 08:50 AM
Si Erik
Nov 18, 2003 06:46 PM
