Intake gaskets
Old Feb 15, 2005 | 10:46 PM
integGSR805's Avatar
Default Intake gaskets
quick question i just got in my Skunk 2 intake manifold in for my 96 gsr and im going to replace the IM gasket. should i go with the factory or one of those Cooler gaskets. Never really heard much about it. Does it make a difference?
Old Feb 16, 2005 | 07:35 AM
cnydc2's Avatar
Default Re: Intake gaskets (integGSR805)
If you go aftermarket you could try the Hondata gasket, if you want to spend that kind of money on a gasket. The idea of the hondata piece makes sense and prolly does help with heat a little but i think that I would save my money and just go with the OEM part.
Old Feb 16, 2005 | 07:38 AM
qcktegls's Avatar
Default Re: Intake gaskets (cnydc2)
just go with the oem gasket. the hondata gasket u need to oem gaskets to go on either side of it neways. plus u'll most likely need longer bolts to put ur manifold on with the hondata. just stick with oem
Old Feb 16, 2005 | 04:28 PM
ok thanks
Old Feb 16, 2005 | 06:12 PM
CougDG's Avatar
Default Re: Intake gaskets (qcktegls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qcktegls &raquo;</TD></TR><TR><TD CLASS="quote">just go with the oem gasket. the hondata gasket u need to oem gaskets to go on either side of it neways. plus u'll most likely need longer bolts to put ur manifold on with the hondata. just stick with oem</TD></TR></TABLE>
Ummmm.... i pretty sure you're wrong because I have that gasket and didn't need to use oem gaskets or longer bolts..
Do some research and search
Old Feb 17, 2005 | 05:16 AM
qcktegls's Avatar
Default Re: Intake gaskets (CougDG)
its recommended that you put it on both sides. its helps it but you dont have to do it. id say about 50 percent of people have to get longer bolts.
Old Feb 17, 2005 | 05:26 AM
VTEC Visions's Avatar
Hondata is a good choice and runs only about $60 new
Old Feb 17, 2005 | 06:26 AM
mraudio13's Avatar
Default Re: Intake gaskets (VTEC Visions)
I put the hondata gasket on mine with two oem gaskets on either side. I had to get longer studs, but if you can take of the intake manifold and replace the skunk 2 then you can spend the 5 bucks it costs for new studs. All you need to replace is the studs anyway...
Old Feb 17, 2005 | 07:40 AM
qcktegls's Avatar
Default Re: Intake gaskets (mraudio13)
yeah they arent that expensive.
heatshield - $60
two gaskets - $20
studs - $5 to $10
EX-T
10
May 4, 2014 08:02 PM
kmeng
11
May 5, 2009 06:45 PM
949
Apr 7, 2009 08:04 AM
H22A4Me
Mar 4, 2006 06:26 AM
HondaIntegraR
Jul 14, 2005 11:23 AM
