Question....
2.A. Please do not post misleading or unspecific thread titles. Please don’t post “Help Needed” or “Look at this problem.” Make your thread titles specific to the question you are asking
And to answer your question I believe they are similiar but not exactly the same.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9800 »</TD></TR><TR><TD CLASS="quote">2.A. Please do not post misleading or unspecific thread titles. Please don’t post “Help Needed” or “Look at this problem.” Make your thread titles specific to the question you are asking
And to answer your question I believe they are similiar but not exactly the same.</TD></TR></TABLE>
Sorry. I had to reply to a friend if it was the same at the last minute. But do you think so that it's a little different? Because I cant realize why Honda will change the 05 civic suspension dimension from the 01~04 model. I have the feeling it's the same. Basically I just told him to call Tokico to see if they are the same.
after roughly 1.5-2 minutes of looking on that link I gave you I found out that 01-02 struts use 14mm bolts and 03-04 use 16mm bolts. In order to get the older struts to work with the new car you need to drill out the holes.
Springs are the same according to Eibach.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonsense »</TD></TR><TR><TD CLASS="quote">after roughly 1.5-2 minutes of looking on that link I gave you I found out that 01-02 struts use 14mm bolts and 03-04 use 16mm bolts. In order to get the older struts to work with the new car you need to drill out the holes.
Springs are the same according to Eibach. </TD></TR></TABLE>
What about the 05 model?
do you think it's still the same as the 03~04 model?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JunY »</TD></TR><TR><TD CLASS="quote">
do you think it's still the same as the 03~04 model?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonsense »</TD></TR><TR><TD CLASS="quote">I don't know, but these guys might:
http://www.7thgencivic.com/
my point was SO YOUR OWN DAMN RESEARCH. It's not that hard
do you think it's still the same as the 03~04 model?</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonsense »</TD></TR><TR><TD CLASS="quote">I don't know, but these guys might:
em1woot
Oct 19, 2007 01:47 PM
