RPM?
Old Feb 15, 2005 | 08:07 PM
opiumdaze's Avatar
Default RPM?
Not sure what this would mean but what is wrong if my RPM's fluxuate when i have the RPM's held?
Modified by opiumdaze at 12:26 AM 2/16/2005
Old Feb 15, 2005 | 08:21 PM
The Phil's Avatar
Default Re: RPM? (opiumdaze)
you don't hold your RPMS at a throttle position, you hold the throttle at that position. How bad is the fluctuation (sp?)? Within ~100rpm or like ~1500rpm?
Old Feb 15, 2005 | 08:26 PM
opiumdaze's Avatar
Default Re: RPM? (xthephilx)
about + - 100rpm
Old Feb 15, 2005 | 08:29 PM
The Phil's Avatar
i don't think that's a problem...my RPMs go up and down in little bits if i try to hold a rev. While we're at it...did you recently change anything on your motor? Add intake/header/etc? Also, try resetting the ECU to see if the problem goes away.
Old Feb 15, 2005 | 08:32 PM
opiumdaze's Avatar
actually today i changed my header but even then it was doing this before... i put the motor back about 2800 miles ago and it has just started doing this 100miles ago i will reset the ecu tomorrow
Old Feb 15, 2005 | 08:42 PM
The Phil's Avatar
aite...tell me how resetting the ECU goes
Old Feb 15, 2005 | 09:08 PM
B3HEMOTH's Avatar
http://www.team-integra.net/se...ID=82
carendell
Oct 24, 2013 09:13 PM
dturbo
Sep 28, 2005 06:52 PM
92-LS-Civic
Dec 1, 2004 08:30 PM
riceball777
Jun 4, 2003 09:46 AM
Goldenboy
Jul 29, 2002 12:13 PM
