newbie need a quick reponse if possible
Old Feb 15, 2005 | 05:52 PM
smiths54aub's Avatar
Default newbie need a quick reponse if possible
what happens if you over fill the b18c1 by a quart or so with oil i think i did and the car sounds kinda funny. go ahead make fun but please respond. thanks
Old Feb 15, 2005 | 07:49 PM
xTravBx's Avatar
Default Re: newbie need a quick reponse if possible (smiths54aub)
a quart isnt in -insane- amount - but it's definitely not good. I've heard of auto x'ers putting in an extra half quart..
I would drain it out. You could probably hurt your rings.
Old Feb 15, 2005 | 11:49 PM
Hapexamendios EJ8's Avatar
blow an oil seal
Old Feb 16, 2005 | 07:36 AM
BLT2FLY's Avatar
Default Re: newbie need a quick reponse if possible (Hapexamendios EJ8)
Drain the oil and put the right amount back in it...Just to be safe
Old Feb 16, 2005 | 02:43 PM
Default Re: newbie need a quick reponse if possible (BLT2FLY)
thanx for the input
Old Feb 16, 2005 | 05:52 PM
4drmadness's Avatar
refilling and adding the correct amount is the way to go.
Hope you didn't drive and run it alot w/ to much oil in it.
Good luck and hope all is well..
Old Feb 16, 2005 | 09:14 PM
ProjectDarkBlack's Avatar
Default Re: (4drmadness)
ive seen a teg with 7 quarts of oil in it. On the freeway i had to change lanes because all i could see was black cloud, i had nothing to do with him tho. He decided to burn it out, i would definately not run it like that. Maybed you drop the oil into a bigger measuring cup until you get close to one quart
"Ridge"Racer
Honda Civic (2006 - 2015)
Aug 8, 2007 05:22 PM
97akwerd
Aug 8, 2005 01:46 PM
DVS Luder
Oct 24, 2004 01:55 PM
blkbeast
May 28, 2003 10:48 PM
slickboy
May 25, 2002 12:06 AM
