'96 JDM ITR Header
Old Jan 17, 2002 | 05:47 PM
forksports's Avatar
Default '96 JDM ITR Header
Will this fit on GSR without modifying the exhaust piping? how big is the collector, cause it looks like 2.5", I guess that gonna be a problem. Will this make any improvement over stock GSR header? allright, any thoughts will be appreciated
Old Jan 17, 2002 | 06:03 PM
sgT's Avatar
sgT
Default Re: '96 JDM ITR Header (forksports)
Fitment should be the same as the honda 4-1 header.
Old Jan 17, 2002 | 06:26 PM
Benjamin Tang's Avatar
Default Re: '96 JDM ITR Header (sgT)
96specr is cast upper and ss lower as i recall correctly? sgt?
Old Jan 17, 2002 | 08:27 PM
sgT's Avatar
sgT
Default Re: '96 JDM ITR Header (Benjamin Tang)
correct.
Old Jan 17, 2002 | 08:47 PM
SamB's Avatar
New User
It's 2.5" OD, the inside is only 2"
Sam
Old Jan 17, 2002 | 08:56 PM
sgT's Avatar
sgT
Default Re: '96 JDM ITR Header (Sam & Bridget)
what??
we arent talking about US model.
Old Jan 17, 2002 | 09:02 PM
SamB's Avatar
New User
Not sure I follow you sgT??? - I was referring to his question about the collector being 2.5"
Old Jan 17, 2002 | 09:10 PM
sgT's Avatar
sgT
flange is about 2.5" but even with the antireversion chamber the opening is
still larger than 2"
Old Jan 17, 2002 | 09:36 PM
SamB's Avatar
New User
*runs out to garage, measures '96 Spec JDM header sitting in corner*
The ID of the opening is 53mm = 2.086614inches
Guess I should have said I measured the ID
Sam
Old Jan 17, 2002 | 10:19 PM
GokuSSJ4's Avatar
should fit just find but you need to modified the piping !
Old Jan 18, 2002 | 07:42 AM
sgT's Avatar
sgT
Wow.
So the outerwall on the flange is 60mm?
Old Jan 24, 2002 | 11:20 AM
hondatwincam's Avatar
Dunno if this will help but:
90Rexx
Jul 3, 2012 08:37 AM
AllMotorDan
Northeast (Sales)
21
Feb 11, 2010 11:50 AM
Driven
18
Sep 5, 2005 06:29 PM
DutchITR1689
Mar 31, 2005 04:07 PM
hybridhatch18
Nov 17, 2003 06:35 PM
