Plug Wires?
From: Formerly of SF moved to DFW and now back in SF, CA, USA
First, do you have a built motor? If you aren't running over 200wheel horsepower and aren't running an Ignition box like an MSD than you don't need to upgrade to an expensive set of wires. A fresh set of OE wires and plugs is just as efficient on a stock motor as these "high dollar, high performance" wires. The stock system can handle up to 200whp.
Don't waste your $$ on stuff you don't need. If you still insist on something other than stock get a set of NGK wires. Look in our sponsor section, I think someone had them there for a good price.
Good luck!
Good luck!
