revving - how high should I go
Old Feb 15, 2005 | 12:25 PM
SuedeB's Avatar
Default revving - how high should I go
Ok, I am in the midst of buying a block that is bored to OS CTR's and everything so that will be my block set up with a micropolished crank and everything will be balanced, arp studs and bolts.
my head will have LS Race cams from exospeed and ISKY race valvetrain set up with .500 lift. I am also going to clay my motor. and have a bored pnp i/m bored t/b.
I want to get ideas of a safe rev when dragging.. im thinking around 9k ?
Old Feb 15, 2005 | 12:29 PM
Kowalski's Avatar
Default Re: revving - how high should I go (SuedeB)
9000 sounds nice...
I read somewhere that when you rev to 9000 it puts about 12x more stress on the engine as if you were to rev to 8000.
Keep that in mind as you spin that **** to 9k+ :D
Old Feb 15, 2005 | 12:49 PM
greaseball's Avatar
dyno it and see where the power falls off, then go from there. tuning on a high rpm motor is key!!! why rev to 9000 when it only makes power to 8700?
Old Feb 16, 2005 | 04:33 AM
SuedeB's Avatar
yea, and I just read the specs on the LS Race cams I am getting.
power band 2300 - 7200 =o) so I know not to rev over 7200, unless my dyno says otherwise.
Old Feb 16, 2005 | 05:07 AM
KingKash420's Avatar
The OG Animated Avatar
damn 2300 to 7200 is a pretty wide powerband!
Old Feb 16, 2005 | 05:40 AM
HONDA RR's Avatar
I would around 9000 would be ok.
Old Feb 16, 2005 | 07:30 AM
95lstegman's Avatar
Default Re: revving - how high should I go (MITSUBA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kingkash420 &raquo;</TD></TR><TR><TD CLASS="quote">damn 2300 to 7200 is a pretty wide powerband!</TD></TR></TABLE>
i think they just mean it doesn't make anything good til 2300 and it doesn't make anything good after 7200. powerband is probably 4000-7000ish. a little higher end than stock, if it really does go that high, but those "LS Race" cams sound tiny. shoot, my 404's in a STOCK head casting and stock block the torque doesn't fall off until practically 6000rpm, so the real power of the cams will be maybe 5500 to at least 7500, and 8000 will probably be a good shift point once my block is ready for it. i plan on some mild work to the head and a few minor but important block upgrades to get it to 8000, and then get a cheap $20 chip to raise the redline to 8000 and retune so the chip fuel curve doesn't F* me up.
Old Feb 16, 2005 | 07:32 AM
cnydc2's Avatar
9000 should be OK. Put the car on the dyno and see where you are making power and set you rev limit where the power drops off.
Old Feb 16, 2005 | 09:18 AM
SuedeB's Avatar
the cams are re-grinds.
specs as follows.
Wild street/ race cam
* rough idle
* powerband: 2500 to 7200 rpm
* if you are worried about gas mileage…
this isnt for you.
* HP increase with bolt ons- up to 20hp
* Requires valvetrain upgrade
* Highly recommend with headwork
Old Feb 16, 2005 | 09:22 AM
95integraLS's Avatar
Default Re: (SuedeB)
Screw it...rev to 15k! You only live once!
Old Feb 16, 2005 | 12:00 PM
SuedeB's Avatar
will do!
haha when I blew my motor it was revved to 4k in second gear!
but the rod was already knocking against the block haha!
Old Feb 16, 2005 | 12:01 PM
The Phil's Avatar
regrinds
forryk
15
Sep 12, 2010 04:04 PM
4 door beast
Sep 13, 2009 05:35 AM
JokerTypeR
34
Apr 25, 2005 05:59 AM
allmotor235
Apr 23, 2005 09:09 PM
StinkyTofu
Feb 17, 2003 11:16 PM
