Aem fuel rail...
Old Feb 15, 2005 | 12:15 PM
Lee_Delso's Avatar
Default Aem fuel rail...
Need advice on aftermarket fuel rail. how does it compare to OEM? when would you need one? is it worth it?
All I got now is i/h/e. Do I need it for future tuning or is it just bling? Give me your opinions.
Old Feb 15, 2005 | 12:23 PM
Ghetto Civic HX's Avatar
I love to drive
Default Re: Aem fuel rail... (Lee_Delso)
From AEM/DC Sports website:
http://www.aempower.com/product_fuel.asp
High Volume Fuel Rail
AEM High Volume Fuel Rails feature a 1/2-inch fuel bore capable of flowing enough fuel to support most high-horsepower applications. This large bore also dampens back pulses created by larger injectors, and works perfectly with stock injector sizes. An additional 1/8th NTP port is included to accommodate a nitrous set up or fuel pressure gauge. A custom fuel line fitting is included for the factory fuel line, and the ends of the rail are pre-tapped to accept -6 or -8 AN fittings for users with custom fuel lines.
Key Features:
No additional parts required for installation
Specifically engineered for each application
O.E. fuel pressure regulator, or AEM adjustable fuel pressure regulator, mounts directly to rail
Comprehensive installation instructions, hardware, fittings and injector O-rings included
Manufactured and assembled in the USA
Old Feb 15, 2005 | 12:25 PM
snatch's Avatar
Default Re: Aem fuel rail... (Ghetto Civic HX)
With just I/H/E I wouldn't bother, it's more of a bling factor than anything at this point.
POE's Avatar
POE
u dont need to waist your money on that fuel rail, u dont have enough modds for it to make a diffence on your car. save that money to get a cam gear or somthing fuel regulaltor and a gauge, for tuning later down the road.
Old Feb 15, 2005 | 03:06 PM
SOHCD16y8's Avatar
just bling, you dont need it with those mods, save and get some cams or something
Old Feb 18, 2005 | 06:59 PM
memicah's Avatar
Default Re: (SOHCD16y8)
yea, any aftermarket fuel rail is only bling. you're good with the stock rail for over 400hp. search it.
prostreetonline
Aug 17, 2004 09:01 AM
