LS Vtec Question (Main girdle Importance)
Old Feb 14, 2005 | 09:52 PM
j87w's Avatar
Default LS Vtec Question (Main girdle Importance)
I have searched around and it seems I cant find a good straight answer. Im building a LS Vtec engine. Its going to be my daily driver and rev no higher than 8800 rpms. Im going to balance the bottom end. My question is that do I really need a main girdle. Im using ARP main studs also. I found the Golden Eagle kit and its like $420 plus you need to have the mains bored/honed. I need it to last a while but Ive heard alot of people spinning bearings because of the girdles. I need some feedback from people who have done this or have seen what happens.
Thanks for input.
J
Old Feb 15, 2005 | 04:29 PM
j87w's Avatar
Default Re: LS Vtec Question (j87w)
bump
Old Feb 15, 2005 | 08:30 PM
j87w's Avatar
anyone?
Old Feb 16, 2005 | 06:44 AM
PrettyLude's Avatar
it would be worth it to have a girdle to make the bottom end more rigid
Old Mar 3, 2005 | 08:16 PM
j87w's Avatar
Default Re: (PrettyLude)
bump any one else ?
Old Mar 3, 2005 | 08:34 PM
vaporboy12's Avatar
i rev my built ls/vtec to 9500 no girdle here
Old Mar 3, 2005 | 08:54 PM
neogenesis2004's Avatar
Default Re: (vaporboy12)
from what ive seen the b16 has no main girdle either. I plan on only using b16 arp main studs on my build
Old Mar 3, 2005 | 08:57 PM
Combustion Contraption's Avatar
Default Re: (neogenesis2004)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neogenesis2004 &raquo;</TD></TR><TR><TD CLASS="quote">from what ive seen the b16 has no main girdle either. I plan on only using b16 arp main studs on my build</TD></TR></TABLE>
You are correct the b16 has no main girdle but that is only because of its superior internal geometry compared to the 1.8l b series block. Piston speed is lower at high rpm on a b16 (less friction) and the r/s ratio is in the neighborhood of 'perfect' (less friction, less vibration.) For these reasons, honda did not put a girdle on the b16a's...
Old Mar 3, 2005 | 09:44 PM
j87w's Avatar
Default Re: (LsVtec92Hatch)
I think im just going to buy a gsr girdle, ect and modify it to fit my ls block instead. I decided Im going to go ahead and put it on there.
Old Mar 3, 2005 | 10:05 PM
KFBhonda's Avatar
Default Re: (j87w)
put a girdle on it.
honda does **** for a reason.
at least some of the time the engineers beat out the accountants and functional parts make it onto a production engine.
the girdle on the vtec b18's hold the bottom end together at high rpms.
if you take a non-vtec b18 bottom end and make it spin to vtec rpms then it only makes sense to modify it accordingly.
MPF_supra
Apr 13, 2008 09:59 PM
CO_CReX
Aug 22, 2007 08:26 PM
Ha Itz
Jul 8, 2005 05:04 AM
Andres-eh2
Jan 20, 2005 11:55 AM
bens_redeg
10
Sep 4, 2004 12:28 PM
