WTH my Ninja is overheating again
Old Feb 14, 2005 | 08:15 PM
Jay J's Avatar
Prince of Zamunda
Default WTH my Ninja is overheating again
It did this when it had 150 miles and is doing the same now with 300 miles. The temp gauge gets close to the overheated mark(a bar space or 2 before the too hot mark) and as soon as its off it turns the fans on by itself.. I did not fool around with it today but last time I started it without a cap on the radiator and idled for a few seconds and it was normal after that...
Old Feb 14, 2005 | 08:38 PM
Etylorcen's Avatar
Default Re: WTH my Ninja is overheating again (Scoobywrx)
How hot does it get in degrees? Bars mean nothing to me.
Old Feb 15, 2005 | 07:18 AM
EFz6er's Avatar
Default Re: WTH my Ninja is overheating again (Etylorcen)
are you low in coolant?
Old Feb 15, 2005 | 07:46 AM
falcongsr's Avatar
What is this crap?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Etylorcen &raquo;</TD></TR><TR><TD CLASS="quote">How hot does it get in degrees? Bars mean nothing to me. </TD></TR></TABLE>
heh. its a ninja 250, its only got a simple needle gauge.
smart to keep it out of the red. did you bleed the coolant system? i guess thats why you had the cap off? its brand new? are the fans turning on automatically or only when you cycle power?
Old Feb 15, 2005 | 11:03 AM
rioninja's Avatar
Im not exactly sure when the thing is overheating on you..
If it overheats when your riding:
Either air in the system, or a sticky thermostat.
If the only problem is the fans not turning on when they should:
Replace the thermoswitch.
Old Feb 15, 2005 | 02:31 PM
Jay J's Avatar
Prince of Zamunda
Default Re: WTH my Ninja is overheating again (rioninja)
Well I took the cap off and let it idle reinstalled the cap on the radiator and it was normal... But now its starting to do it again. As for coolant its full in the radiator and reservoir. The fans turn on after I turn off the bike, not while its idling
Old Feb 15, 2005 | 02:51 PM
rioninja's Avatar
So, does it overheat when your riding? or only when your sitting still?
Old Feb 15, 2005 | 03:48 PM
Jay J's Avatar
Prince of Zamunda
Only when after riding--&gt; idling or low rpms.
Old Feb 15, 2005 | 03:49 PM
rioninja's Avatar
Test the thermoswitch. This can be done with a volt meter, and a pot of water on the stove.
Old Feb 15, 2005 | 05:13 PM
MaxSterling's Avatar
you got a bubble trapped in the coolant system, so water isn't circulating. completely drain coolant, flush using running water (water hose), and add fresh coolant.
Old Feb 15, 2005 | 07:01 PM
Jay J's Avatar
Prince of Zamunda
Default Re: WTH my Ninja is overheating again (MaxSterling)
Is the volt meter for checking temp? If so I have a laser temp gun(for my RC's which I use) and a Temp probe -temp gauge with a wire/sensor
Old Feb 15, 2005 | 07:03 PM
Tiferet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scoobywrx &raquo;</TD></TR><TR><TD CLASS="quote">It did this when it had 150 miles and is doing the same now with 300 miles. The temp gauge gets close to the overheated mark(a bar space or 2 before the too hot mark) and as soon as its off it turns the fans on by itself.. I did not fool around with it today but last time I started it without a cap on the radiator and idled for a few seconds and it was normal after that... </TD></TR></TABLE>
If it only has 300 miles, take it back to the dealership.
Old Feb 15, 2005 | 08:50 PM
Jay J's Avatar
Prince of Zamunda
Default Re: WTH my Ninja is overheating again (L.D.S. Construction)
I bought it in June.. Dealer is the most overpriced scumbag place in the area.. I overpaid big time..
Old Feb 15, 2005 | 10:36 PM
ScareyH22A's Avatar
Honda-Tech Gold Member
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scoobywrx &raquo;</TD></TR><TR><TD CLASS="quote">I bought it in June.. Dealer is the most overpriced scumbag place in the area.. I overpaid big time.. </TD></TR></TABLE>
I see that you're in Torrance. Take it to Mach 1 in Costa Mesa? New Port? Anywho, they take care of people well.
Old Feb 16, 2005 | 04:46 AM
Jay J's Avatar
Prince of Zamunda
Default Re: WTH my Ninja is overheating again (ScareyH22A)
If you've heard of Del Amo motorsports that's where I got it from
Old Feb 16, 2005 | 04:52 AM
Tiferet's Avatar
If you only have 300 miles, it would be free, thats what the warranty is for.
Old Feb 16, 2005 | 05:37 AM
Jay J's Avatar
Prince of Zamunda
I said no to "their warr"... Are you talking about the factory one?
Old Feb 16, 2005 | 08:05 AM
typeeg's Avatar
It's either a air bubble in your coolent system or a faulty thermostat that's stuck closed.
Take it into the dealership like the others have said. I believe all kawasaki bikes come with 1 year factory warrenty.
If you plan on keeping this bike you might want to get the extended good times warranty.. well worth the money
Old Feb 16, 2005 | 08:29 AM
EFz6er's Avatar
Default Re: WTH my Ninja is overheating again (Reckless636)
did you fill the coolant at all? If so did you fill the reservoir or the radiator? If you filled the res. then you have air trapped inbetween the res. and the rad. therfore causing you to overheat.
bleed the system
Old Feb 16, 2005 | 09:04 AM
rioninja's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scoobywrx &raquo;</TD></TR><TR><TD CLASS="quote">Is the volt meter for checking temp? If so I have a laser temp gun(for my RC's which I use) and a Temp probe -temp gauge with a wire/sensor </TD></TR></TABLE>
No, the voltmeter is for testing continuity of the thermoswitch. Its basically a temperature operated on/off switch.
Old Feb 16, 2005 | 01:50 PM
Tiferet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scoobywrx &raquo;</TD></TR><TR><TD CLASS="quote">I said no to "their warr"... Are you talking about the factory one? </TD></TR></TABLE>
Yes the factory warranty.
Old Feb 16, 2005 | 04:11 PM
Jay J's Avatar
Prince of Zamunda
Default Re: WTH my Ninja is overheating again (EFz6er)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFz6er &raquo;</TD></TR><TR><TD CLASS="quote">did you fill the coolant at all? If so did you fill the reservoir or the radiator? If you filled the res. then you have air trapped inbetween the res. and the rad. therfore causing you to overheat.
bleed the system </TD></TR></TABLE>
It's topped off on both. It was never to the full mark on the reservoir when I got it so I added some fluid to it to be on the F.. I'll try bleedling out the system on friday..
Johnrb
Apr 19, 2012 07:09 AM
RG400SmartTowel
Aug 11, 2009 12:34 AM
924doorEG
Aug 16, 2007 12:44 PM
I_dont_want_a_user_name
Dec 22, 2006 10:29 AM
HatchedGTI
Feb 10, 2006 10:47 AM
