Crower stage 3 cams....
Who is running the stage 3s? any problems with daily driving on them?
Im build my all motor H22 and got some crower 3s for a smoking deal. but im not sure if theya re going to be able to hold up. I hvae read about people breaking them and Brian Crower(owner) informed me that its mostly do to installation error. I also have the new batch that is supposedly 20% stronger than the old ones. But im unsure if they will hold 10k revs.....
BTW does anybody have any dyno's for the crower 3s?
any help is appriciated!
Aeolus has run Crower 3's:
215whp and 159wtq
eagle rods,wiseco pistons,stock h22 crank
crower stage 3's
mild ported head and stock manifold
64.5mm tb
DC header primaries with a remade custom sencondary piping and 2.5" merge collector
2.5" exhaust and piping.
aluminum flywheel
no counter balance shafts
p28 hondata s100
https://honda-tech.com/zero...58931
I don't see why you would want to spin to 10,000rpm. It appears like the peak on the 3's is about 8K.
Pirate
215whp and 159wtq
crower stage 3's
64.5mm tb
aluminum flywheel
p28 hondata s100
Pirate
haha youll never make power to 10k mostly, thats why eveyone blows up their Ls/B20 vtec's. But im about to crank my motor that has some Crower stage 3's in it. Im just wondering if they are good cams or to big to run on 12.5 cmp
i will be running the same compression. Power has already been mad to 10k before on a H so im not worried about what people "say". Im just worried if the cams can handle the rev's.
Everything else can handle 10k+ revs it just comes down to the cams......
gaydm.accord
Jun 9, 2004 06:48 AM
