gettn screwd by the dealer and a auto shop
Old Feb 14, 2005 | 06:32 PM
01 GEEEZER SLEEPER's Avatar
Default gettn screwd by the dealer and a auto shop:: has been deleted
this topics has been deleted..
thanx for making feel dumb punks.. ive learnd my lesson now
Modified by 01 GEEEZER SLEEPER at 2:26 AM 2/15/2005
Modified by 01 GEEEZER SLEEPER at 2:27 AM 2/15/2005
Old Feb 14, 2005 | 06:37 PM
a1320addict's Avatar
Default Re: gettn screwd by the dealer and a auto shop (01 GEEEZER SLEEPER)
honestly...no they shouldnt....you shouldnt be drivin your car like that "all day"...and you never said who actually performed service on the car...did you get the valve job? if so...why the hell would you go and push it the next day
boo for stupidity
Old Feb 14, 2005 | 09:04 PM
yea i got the valve job but after that i didnt open it up when i got it back... when it it broken down on me.. i opend up the CAM cover and the belt was loose and the other side was tight.. i think they shouldnt make me pay for it..
Old Feb 14, 2005 | 09:05 PM
rough_draft's Avatar
dealer warrenty wont cover over rev. my buddie over revved his type s and he couldn't get it covered.
Old Feb 14, 2005 | 09:22 PM
kchungb17a's Avatar
Default Re: (Lmaonade)
Yeah, when they said drive it hard, and we'll fix it if it breaks, they didn't mean they'll fix it if YOU break it, which is what happened. No dealership is going to cover anything if they even suspect that you overrevved the engine. It's likely you bent some valves. Did the shop change any valves? Pressure test the head? If all they did was a valve job, then I doubt that solved anything. You should have a warranty from them, especially if the work they performed didn't fix the prblem. At the very least, all you should pay for is to replace valves, but not for any work that was already performed (R&R head, valve job). There's always the Bureau of Automotive Repair, if you need some help. BTW: a blinking check engine light means that there is a catalyst damaging event in progress, ie misfires, which can be the result of, among other things, bent valves. Cam timing that went out due to a loose timing belt can cause misfires too!
Old Feb 14, 2005 | 09:26 PM
GsrGilbert's Avatar
Default Re: (kchungb17a)
run on sentences owns u...
but still im sorry to hear about this, maybe u should take some time to understand exactally what ur warrity covers and exactally what is wrong with ur car...
Old Feb 14, 2005 | 09:57 PM
Avenged7x's Avatar
Default Re: (GsrGilbert)
Screwed by dealer? no u screwed yourself. Screwed by the auto shop? who knows but i doubt you'll get any money back at all. So spend the 450 to get it fixed somewhere else or suck it up and do it at the same place.
Old Feb 14, 2005 | 10:38 PM
.water's Avatar
burn down that shop who fuked ur car..find some good feedback shop and spend well money to fix it right 1st time...sorry to hear that u spend lots of money by getto *** shop
Klasse
Feb 12, 2021 02:42 AM
Skatnshawn
Nov 22, 2012 10:30 PM
kenny707
15
Jan 17, 2009 08:52 AM
BoltonGSR
Jun 7, 2008 12:05 PM
94Gizzer
Mar 26, 2003 10:07 AM
