Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Attending driving class/HPDE in March, advice for car prep?
Old Feb 14, 2005 | 05:07 PM
Mr.Saturn's Avatar
Default Attending driving class/HPDE in March, advice for car prep?
To keep it short and simple, I'll be attending this event in late March and will be using my daily driven CRX. It will be my first time doing anything like this and aside from checking brakes, tires and fluids, what else would everyone recommend double-checking or refreshing before I go?
Old Feb 14, 2005 | 06:02 PM
.RJ's Avatar
.RJ
Default Re: Attending driving class/HPDE in March, advice for car prep? (Mr.Saturn)
There's gotta be something in the Forum FAQ...
Old Feb 14, 2005 | 06:35 PM
Mr.Saturn's Avatar
Default Re: Attending driving class/HPDE in March, advice for car prep? (.RJ)
I got the "Since you will be driving fast for quite a while, it is strongly suggested you check your tires, bleed the brakes, and check the pads before you go." but I just wanted to see if there were any other little bits of advice I could get, like any parts on a 15 year old (but still well maintained) car that should definately be checked.
Old Feb 14, 2005 | 06:41 PM
.RJ's Avatar
.RJ
well i give some parts of my car a thorough inspection between events - wheel bearing, tie rods inspection, brake system inspection (remove calipers, check the lines, abs wires/sensors, etc for wear/leaks), earl leaks under the hood, and so forth. And a few times a year I will check the torque on all the susp bolts and inspect the b00shings. I would do all of that if the car has not seen track duty. It can take a while, but take care of your equipment and it will take care of you
Old Feb 14, 2005 | 06:43 PM
Mr.Saturn's Avatar
thanks for the help!
flatblackintegragsr
May 30, 2006 11:21 AM
hmongboyLS
Jan 30, 2004 01:09 PM
yazac
Aug 16, 2003 12:55 AM
Double 06
Dec 19, 2001 07:09 PM
Inigo Montoya
Sep 28, 2001 10:03 AM
