Wiring diagram for 02 sensor plug?
The plug slipped off the pins of my 02 sensor(sensor plug not engine Harness.)
Nothing is damaged,Being 02 sensors are like 200.00 Id like to reinstall the pins in the connector, but I dont know what wire goes to where in the plug.
Theres 4 wires.
Has anyone tried those universal 02's where u put the wires on the origional connector? Im basically doing that but with the factory plug so I can get it to work properly.
Theres 4 wires.
I had a spare one laying around, but couldn't find it. So I just stole this pic off of eBay. It's not the most detailed, but I think you can figure out where the wires go...
From the pic, it looks like the bottom of the connector is the piece with the tab that you have to push to unlock the connector. The half facing up appears to be the part that would clip the actual connector to a mounting point. That said, the two black wires go to the side that is the mounting point. The green wire goes on the clip latch side and the white wire on the other side. If you just look at the picture it should all make sense. Hope this helps, I know it's not the best...
-- Kevin
-- Kevin
jwbnavy
Dec 4, 2007 02:20 PM
Ritchie
25
Apr 27, 2007 01:17 PM
