what ecu to use with sohc vtec zc?
Old Feb 14, 2005 | 11:13 AM
Discosteak's Avatar
Default what ecu to use with sohc vtec zc?
like the title states i am currently using the p08 because the zc is using a single wire o2 sensor. but should i be using the p28? or is there another ecu i should be using? TIA
Old Feb 14, 2005 | 11:21 AM
v4lu3s's Avatar
RTFM
whats wrong with the p08? its the ecu that came with the engine in japan.
Old Feb 14, 2005 | 11:23 AM
Discosteak's Avatar
Default Re: (v4lu3s)
the p08 came with my d15b which was a 1.5 my zc is a 1.6
Old Feb 14, 2005 | 11:24 AM
DelSolSi93's Avatar
Default Re: (BADEG6)
I think you could probably use either the P28 ore P08, P08 is the better choice of the two
Old Feb 14, 2005 | 12:23 PM
Discosteak's Avatar
Default Re: (DelSolSi93)
bump
Old Feb 14, 2005 | 12:24 PM
BauleyCivic's Avatar
Risky Business
Default Re: (BADEG4)
P08 should work fine...if you're really worried hook a WB up and look at your AF ratios
Old Feb 14, 2005 | 12:51 PM
Jmunk's Avatar
You could use a p28, than you have to get a 4 wire o2 and run the additional wires to the ECU depending on the harness your using and the model of your car. Nothing too hard.
projectpd
Jun 15, 2007 02:20 PM
KingDanOne
37
Oct 10, 2006 01:17 PM
ZC CivicJdm
Jun 2, 2006 04:59 AM
egizzle8
Sep 20, 2004 12:55 PM
