Corrosion in engine compartment
Old Feb 14, 2005 | 05:06 AM
atuvy's Avatar
New User
Default Corrosion in engine compartment
I own a 2000 Honda Accord with a 4 Cyl. engine. Recently I noticed that there is some corrosion of parts in the engine compartment, steel screws have some red rust on them and Aluminum parts are covered with the white powdery stuf typical to Aluminum corrosion. In addition to that the Battery which is the original battery shows signs of "please replace me". I wonder if the corrosion problem is related to the battery or else what is causing it. BTW I do not live near the beach.
Thanks
Old Feb 14, 2005 | 05:59 AM
sj993's Avatar
Default Re: Corrosion in engine compartment (atuvy)
It's normal for screws to get rusted over time. As for as the white stuff it could be from the battery. Where is it located? If it's near and around the battery then I would say that's fairly likely.
Ryan Hammond
Oct 2, 2014 12:48 AM
justmeandher
19
Mar 12, 2014 05:21 PM
emegge
Aug 10, 2006 04:07 PM
shanmanz
Sep 15, 2005 03:11 PM
mskibbz-T
Apr 27, 2004 03:12 PM
