Clutch/Flywheel install. . .car wont start
Old Feb 13, 2005 | 11:41 PM
dAng! Kris's Avatar
Default Clutch/Flywheel install. . .car wont start
Today I just put a Action 2md clutch and a act prolite flywheel in my gsr-t today and now the car wont start. Everything to my eyes is hooked up properly. Just when I turn the key it just clicks once. The fuel pump primes and I have power. I even tried using another car to jump mine but still nothing. Anyone have any ideas to help me out I need to get my car running asap. Thanks everyone in advance.
Old Feb 14, 2005 | 06:20 AM
JimBlake's Avatar
Default Re: Clutch/Flywheel install. . .car wont start (Frozty)
Loose ground cable? Or the big power cable to starter?
Old Feb 14, 2005 | 06:55 AM
s2kkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frozty &raquo;</TD></TR><TR><TD CLASS="quote">Today I just put a Action 2md clutch and a act prolite flywheel in my gsr-t today and now the car wont start. Everything to my eyes is hooked up properly. Just when I turn the key it just clicks once. The fuel pump primes and I have power. I even tried using another car to jump mine but still nothing. Anyone have any ideas to help me out I need to get my car running asap. Thanks everyone in advance.</TD></TR></TABLE>
JUST had this problem in my Gsr I put my fresh rebuilt engine into.
Same click.
Check, and sand the positive cable on the starter, and check and sand the transmission ground cable. It should attach to the body of the car.
sanding will grind off the corrosion and leave a bright copepr finish.
This fixed my problem..
Old Feb 14, 2005 | 07:18 AM
dAng! Kris's Avatar
Default Re: Clutch/Flywheel install. . .car wont start (vtecluder97)
awesome, Thanks I'll try it today
LU!SKEY
Mar 9, 2011 09:23 AM
Circa
Aug 3, 2007 04:49 AM
ragethemachine86
Sep 28, 2006 02:38 PM
2K Teggy
Nov 30, 2004 10:18 AM
