will a stock alternator charge 2 batterys
Old Feb 13, 2005 | 10:55 PM
Jammersplace's Avatar
Default will a stock alternator charge 2 batterys
i have a 99 civic ex with a b18 swap stock alternator i came across a battery given to me from a friend that upgraded. was wondering if i could put it on my car with the stock alternator.
Old Feb 13, 2005 | 11:06 PM
nocturnaldragon's Avatar
Default Re: will a stock alternator charge 2 batterys (Jammersplace)
It wuold work for a short period b4 burning up. Why do you want two batteries in the first place?
Old Feb 13, 2005 | 11:34 PM
Hatchamaback's Avatar
Well it depends on battery strength etc. Continuity discharge rate on a alternator is usually around 14.5 to feed a 12VDC battery, in my opinion you wouldnt get as an effective recharge rate for the one as opposing for the 2 that you are using, and no im pretty sure the alternator won't burn up.
But lets see what else someone has to say.
Optima batterys! good for series, and also parallel connectivity.
Old Feb 14, 2005 | 05:49 PM
cock_diesel's Avatar
you can do it.....but say buh-bye to alternator ina short while
Old Feb 14, 2005 | 05:58 PM
sohcvtec1995's Avatar
Default Re: will a stock alternator charge 2 batterys (02'specvizzle)
just get a higher amp alt. Or run duals, like the car audio (professional) guys do
Old Feb 14, 2005 | 06:05 PM
jlacoy82's Avatar
71.192.16.183
Default Re: will a stock alternator charge 2 batterys (sohcvtec1995)
Get an isolator.
obuhmyuh
May 28, 2008 03:27 PM
aziaticvang
Jan 7, 2008 03:59 PM
Pooby88
15
Dec 19, 2006 07:53 PM
bonta-kun
May 12, 2003 06:08 PM
