transmission problem. not going in gears
I have a z6 motor and si tranny with act unsprung 6 puck clutch
problen not going in any gears (clutch not dissengaging)
thought was through out bearing , pulled motor took off tranny and it is fine. could it be the act clutch 6-9 months old daily driven
You said you pulled everything apart-so how much is left on the clutch disc?
A six puck has to be a bear in a daily driver.Most likely it's been slowly going out and you never adjusted the clutch cable.
